• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Blender Bridge or Diffeomorphic Morphs
s.dennants.dennant Posts: 3
June 2024 in Blender Discussion
Hi all,
Please help!
I have tried countless times to import a G9 character into blender using both the blender bridge or Diffeomorphic with the HD morph plugin by Xin but there doesn't seem to be a clear way to simply import your character into blender with simple morphs like Nipple HD or any morph I have applied to the character in DAZ.
Blender Bridge was close by creating shapekeys for the morphs but these are weak and don't actually protrude the nipples. It slightly modifies the mesh but it's barely visible.
The diffeomorphic plugin is the most complicated thing plus the xin plugin just makes zero sense.
Literally all I want to do is bring in my G9 figure, complete with Nipples and Navel or any other morph like the Bluejaunte feet sole morph etc into blender so it's rigged and I'll redo the textures myself because DAZ has a terrible way of rendering skin that close up has the texture of an orange peel and blender has a more realistic approach to skin which I've managed to finally get my head around - I've imported the G9 figure as an obj, deleted the daz imported material setup and redone everything using the textures from daz, roughness, SSS, diffuse, Specs and the 8k base skin detail normals plus a custom micro normal for better skin.
As an OBJ I've gotten the G9 character to look pretty darn photorealistic it's just this pesky morph importing that I don't know how to do because all I want is the character rigged without having to import a dense mesh or have to manually rig and weight paint everything.
What am I doing wrong?
  • PadonePadone Posts: 4,019
    June 2024
    As for diffeomorphic.
    HD morphs are not supported by blender. That is, the multiresolution modifier doesn't support morphs other than the base level. This complicates things when you want to load HD morphs in blender. One way is to import the full HD mesh and the morphs for that, another is to bake the HD morphs to dispalcement maps. The Xin addon can do both.
    Of course the easy way is to just import the HD shape with easy import in diffeomorphic, but this will import the shape not the morphs. So you have to apply first the morphs you want in the daz viewport, as nipples for example, these will be baked in the HD shape for export.
  • s.dennants.dennant Posts: 3
    June 2024
    Thanks. I tried to bake maps in Xin from a HD OBJ to apply to the rigged one from daz to blender bridge, but I couldn't get the vector displacement map to show up.  So I tried projecting by shrinkwrapping the hd mesh over the rigged one but that doesn't allow me to move the character without having the Hd one in the same pose. I just want to be able to pose the character in the base mesh but have the subdivision be 4 which would be the HD mesh and only one rigged mess all in all.
    Seems impossible sometimes. You get somewhere then face another problem. Any more suggestions? And I'll try later on this evening.
    June 2024
    The Xin addon works with diffeomorphic, not with the daz to blender bridge.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Advanced/HD Meshes
  • dmnmfdmnmf Posts: 31
    June 2024
    I've ran into the same problem. Fastest way as Padone said is apply them in DAZ and then sculpt them out if you don't need them (with shapekeys if you like).
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
