Directly adding compatibility to product metadata (kind of solved?)
mtl1
I was going through my assets and it turns out that there's a huge amount of Genesis 1 content (namely clothing) I'm not using for Genesis 2 because it doesn't pop up under Smart Content. Yes, I know I could use the Content Library directly, but there should be a way to directly edit a product's metadata for compatibility such that it pops up under Smart Content, no?
Post edited by mtl1 on
Not all products have smart content. You will have to access them through the content library.
I mean, yes I realize that, and there are ways to add metadata such that it appears in Smart Content.
What I'm asking is if there's a way to edit a product with existing metadata (that is, Smart Contented) such that it appears as compatible with other products.
I poked around and found a method that seems to work. This isn't the fastest way to do it since I would prefer some kind of direct database editing, but it seems to do the trick.
1. Find an existing Smart Contented product for Genesis. I used Action Kicker Boots.
2. Navigate to Content Library and find the product in question. Hit the menu button and go into Content DB Editor.
3. Ctrl-click both items and navigate to the compatibility tab.
4. Ctrl-click both items at the bottom, then right click and add compatibility.
5. Select Genesis 2 Female and accept, then click on the down arrows on each one to confirm.
This is adapted off of the Adding Metadata tutorial (http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/packaging/tutorials/adding_metadata/start). The trick was to figure out which parts of the tutorial to skip because the product had metadata already.
Of course, there's tweaking involved with Auto-Fit, but at least now I can see the products directly now.
