Directly adding compatibility to product metadata (kind of solved?)
mtl1mtl1 Posts: 1,508
edited July 2015 in The Commons
I was going through my assets and it turns out that there's a huge amount of Genesis 1 content (namely clothing) I'm not using for Genesis 2 because it doesn't pop up under Smart Content. Yes, I know I could use the Content Library directly, but there should be a way to directly edit a product's metadata for compatibility such that it pops up under Smart Content, no?
Post edited by mtl1 on
  • frank0314frank0314 Posts: 15,111
    Not all products have smart content. You will have to access them through the content library.
  • mtl1mtl1 Posts: 1,508
    I mean, yes I realize that, and there are ways to add metadata such that it appears in Smart Content.
    What I'm asking is if there's a way to edit a product with existing metadata (that is, Smart Contented) such that it appears as compatible with other products.
    I poked around and found a method that seems to work. This isn't the fastest way to do it since I would prefer some kind of direct database editing, but it seems to do the trick.
    1. Find an existing Smart Contented product for Genesis. I used Action Kicker Boots.
    2. Navigate to Content Library and find the product in question. Hit the menu button and go into Content DB Editor.
    3. Ctrl-click both items and navigate to the compatibility tab.
    4. Ctrl-click both items at the bottom, then right click and add compatibility.
    5. Select Genesis 2 Female and accept, then click on the down arrows on each one to confirm.
    This is adapted off of the Adding Metadata tutorial (http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/packaging/tutorials/adding_metadata/start). The trick was to figure out which parts of the tutorial to skip because the product had metadata already.
    Of course, there's tweaking involved with Auto-Fit, but at least now I can see the products directly now.
    736 x 404 - 62K
    662 x 767 - 67K
    665 x 767 - 68K
