Painted Skin: Masks for G8F and G8.1F
jjoyner
in The Commons
Is it likely that some of the content in the new product Painted Skin: Masks for G8F and G8.1F (https://www.daz3d.com/painted-skin-masks-for-g8f-and-g8-1f) can be made to work with G8M and G8.1M? The masks are geoshells and some of the materials are Hierarchial. Thanks.
These should help It swaps the uvmap between Male and Female, though I know you said these are geoshells, it might still work, since I believe the shell use the maps of the original model.
https://www.daz3d.com/uv-swap-for-genesis-81
https://www.daz3d.com/genesis-8-uv-swap-male-and-female-base
I never thought to use them on the male but I did a quick check to see how they work "out of the box". They seem to work on 8.0 male with varying degrees of success - depending on the eyeholes. However they do not work on 8.1 as shown in the last image.
It's possible the uv swap would work, but I don't own it and can't check.
Thanks for the resource suggestions. As a hobbyist/dabller, though, they're more than I want to try at this time.
Excellent!! I thought of sending you a PM but didn't know if you'd be checking that channel or the open forums so soon. Again, thanks!
I just bought it.
