• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Importing ambelics to MD (marvellous designer)
Sam.crickSam.crick Posts: 0
April 2024 in Blender Discussion
Hi,
Doing a 3rd year university project. I need your help.
I have exported the ambelic and have the Tpose where it transitions into the movement.
when importing it into MD it seems fine although maybe on the smaller side.
If it is moved or the piece of clothing are moved it then enlarges and rotates where the front face points upwards.
How can I stop this?
I have two outfits made already on still avatars, is there a way I can give them movement - such as a catwalk - (fashion project) or are they stuck like that.
Any help I would be much grateful for.
Thanks
  • Richard HaseltineRichard Haseltine Posts: 109,284
    April 2024
    That sounds as if you are loading the Alembic file as a blend shape/morph target. Those move the vertices along a straight line from the start position to the end, so rotations will usually shrink (or possibly stretch) the mesh and then scale back the other way.
  • lilweeplilweep Posts: 2,790
    April 2024 edited April 2024
    SMall how? Like 90% the size you want or 10% the size you want. You can adjust scale in several ways, either before exporting from Daz or before importing to MD.
    Are you using Sagan exporter from Daz?
    No idea what you are describing.  You are moving and scaling the alembic in MD and then are acting suprised it is transformed and scaled?
    What is the alembic? The avatar with no clothing, the avatar with clothing? Is the clothing exported as alembic from Daz along with the avatar?
    Why would they be stuck "like that"? MD is simulation, so of course they are not stuck unless you froze them.  Unfreeze them.
    Process:
    1. Export the unclothed daz avatar as Alembic using Sagan.
    1. Before export, make the daz avatar the correct size for your garments. (How? Import your MD garment to Daz and then size your daz avatar accordingly.)
    2. Create pose transition animation from (a) pose that fits the clothing to (b) your start pose. Then (c) animate over timeline for your catwalk animation
    3. Export avatar animation as alembic using the Sagan exporter plugin (SubD = 1 or lower is probably fine)
    2. Import alembic avatar to MD
    3. Simulate the MD garments to fit the avatar at frame 0.
    4. In animation pane, run and record simulation animation.
    5. If issues, rerun after fixing issues, playing with animation simulation settings, animation warp speed, iterations etc, and garment properties, like Particle distance.
    5. Export your animated garments as alembic.
    6. Bring animated avatar and animated garment to your renderer of choice (e.g., Blender).
    Post edited by lilweep on April 2024
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
