My figure's fingers are mutating!
I have 4 figures (and mayber more) I'm having trouble with. They were converted to G9 from G8. When I pose the hand, well, take a look at the picture. I have no idea what's going on here. Any ideas out there?
  • crosswindcrosswind Posts: 10,150
    edited April 2024
    You may need the step of Adjust Rigging to Shape.... Pls try the action from : Edit - Figure - Rigging - Adjust Rigging to Shape, while selecting the character in the scene.
    If it works, then remember to ERC Freeze the body morph properties in Parameters pane.
    Post edited by crosswind on
  • wildbillnashwildbillnash Posts: 784
    edited April 2024
    Crosswind, that first step worked like a charm Thank you.
    But I don't know about the ERC Freeze option. It's not under Parameters. I don't have that option.
    On a side note, when I did that, my Parameters Tab went to the bottom of the list. Do you know how I can raise it back to the top?
    Post edited by wildbillnash on
    You need to firstly switch to Edit mode in Parameters pane with the right-click menu (screenshot 1), then right-click on the body morph property, you'll find ERC Freeze... (screenshot 2).
    As for Parameters pane to the bottom... if it looks like the case in screenshot 3, you can just drag it (hold left mouse button to drag the tab...) to the top.
    551 x 776 - 49K
    554 x 777 - 61K
    553 x 771 - 43K
  • Thanks for the pics. That will help. As far as dragging the tab, I tried it already, several times. Didn't budge. I'm going back and try again. I'm going to ignore Einstein's defenition of insanity. (Doing the same thing several times and expecting different results.)
  • Nope, doesn't work.
  • Okay, just tried the edit mode option, but I don't get the screen you show in your pic. Here's what I got.
    1920 x 1080 - 528K
    Oh... if so, maybe you've locked docking....Pls try pressing Ctrl + U before dragging.
    ERC Freezing should be done on a morph property... Go to the body morph property that you dialed, then right-click on it, you'll see the menu item of "ERC Freeze"...
  • Thanks, I'll check on them. I was wondering if there was somekind of locking taking place.
    edited April 2024
    Well, I guess at figuring out where to find the body morph, etc. But I have no experience it this so I just don't know what you're talking about. Could you shoot me a picture so I can see?
    Oh, the trick worked. I was able to move my tab back where it belong. Thanks again for your help.
    You just select "Currently Used" in Parameters pane, check if there's any dialed body morph property ?
