American Football Field
https://www.daz3d.com/american-football-field?_gl=1*1mu73lm*_up*MQ..&gclid=EAIaIQobChMIqN6T49355AIVjYCfCh0fNA8CEAAYASAAEgJklPD_BwE
This need a morph or something that fills the stands with people. Otjerwise it is just for practice.
  • Richard HaseltineRichard Haseltine Posts: 109,347
    A morph wouldn't do it, a set of billboards (renders of figues on transpaency) would be needed - though fitting them around seats is tricky. I can't recall if the Now Crowd series has a suitable set.
  • xyer0xyer0 Posts: 6,399
    The Colosseum includes billboards in crowd formation that may work as well. Powerage has LowRez People Sitting for Daz Studio in groups of ten at Renderosity.
  • benniewoodellbenniewoodell Posts: 2,000
    If you don't mind using Blender, there's an add-on called procedural crowds that has a cheering crowd option. I'm 99% sure you can paint where you want the crowd too so they'll fill the stadium. I have the add-on and have used it several times but I haven't tried to paint where I want people. But it's worth checking out if you use Blender for stuff.
  • CybersoxCybersox Posts: 9,533
    There are also 4 rows of low-rez seated figures (10 per row) included as part of Shredder's UFC MMA Stadium for DAZ over at Rendo and I actually like the way that they're posed MUCH better than Powerages, as the extreme poses in the latter make it much more obvious that figures are repeating, while the ones Shredder's set look more intense and lack the hands in the air, etc., so that they can be used for things other than a sporting event.  As it is, I have both of those sets, as well as a couple of others, and mix them all at random as needed.
    that could work if the crowd is far enough that you don't notice the clothes.
  • memcneil70memcneil70 Posts: 5,619
    They just woke up after a Toga Party at the Frat House.
    TO-GA! TO-GA!
    Dial up dof until the crowd is just blobs of colour.
    I should point out that for relatively long shots, there's no need to bother with individual billboards.  For situations like that I have an account with Envato Elements that gives me access to use over 10 millions royalty free photographic assets, and it's usually more practically to simply find a photos of crowds from similar angles and either set them over the needed areas in "mega-billboard" at slightly reduced cutout opacity or simply paste them in in Photoshop/Gimp/etc. after for a completely believable result and a lot less effort.  The fact is that, after a certain size, the human eye simply stops seeing those figures as anything except a pattern of bright/dark and color, which is why matte painters were often called in to bulk out crowds in the pre-digital effects era with no one ever being the wiser, while huge "crowds" in minitaure models for many old-school Hollywood epics were often nothing more than hundreds of bits of painted cork floating in shallow trays of water.
  • Roman_K2Roman_K2 Posts: 1,274
    Where is Ray Harryhausen when we need him. wink
    I wonder if some people have different perception... levels, especially across cultures. I think there might be a certain "sweet spot" of having say copies of Lorenzo Lopez in the stands with different hair colors say, and different clothes. Adjust the pose, render against a transparent b.g., repeat. Might there be a certain percentage or degree of occurrences if you will, that might influence perception.
    As yet I have zero experience with coaxing A.I. to fill the stands with "x" amount of crowd "noise" say.
    Here are some results I got with DreamUp on Deviantart which I believe is powered by Stablediffusion. The second one has way too much red in the distant crowd so right away it would need some variation. For the 5th one I included the string "moving around" in my text prompt... the result is an awful lot of repetition in the distant people rising up from ground level, and the uppermost level is almost empty!
    1154 x 692 - 118K
    1154 x 692 - 114K
    1154 x 692 - 136K
    894 x 894 - 129K
    894 x 894 - 128K
