Power Supply in New Desktop Computer
jjoyner
Hello. I’m considering buying an MSI Aegis R 13NUD-463US Gaming desktop with an RTX 4060 Ti with 16 GB VRAM and 32 GB of RAM - https://www.costco.com/msi-aegis-r-gaming-desktop---13th-gen-intel-core-i7-13700f---geforce-rtx-4060ti---windows-11-.product.4000139263.html. The computer comes with a 650 watt power supply. Do you think that will be sufficient to not potentially cause future problems?
The recommended for that card is 550, so you should be fine
OK. Thanks much for your thumbs up!!
You might want to consider more RAM to get full potential of that 16GB VRAM card, as Daz Iray tends to use 2x to 3x the amount of RAM as VRAM used in the scene.
As a former computer hardware tech, I'd always consider a slightly higher wattage or better efficiency PSU to leave a bit of room for future upgrades.
But I understand budget means sometimes you can't have everything you want at least at first.
Personally, I would get a 700-750W PSU to be able to cover upgrades in the future so you don't have to also replace it.
If I were building a PC or buying an already built beast of a PC, I'd go with more RAM and a more robust power suppply, but the referenced PC is an already built item at a good price -customizing is not an option. As a dabbler/hobbyist (and now retired), I have no immediate need to have/build a beast of a PC at present, but future upgrades are not out of the question. At present, my Daz Studio (and other 3D programs) PC is a laptop with 16 GB RAM and an RTC 2060 card with 6 GB of VRAM.
Motherboard specs:
https://www.msi.com/Motherboard/PRO-B760-VC-WIFI/Specification
https://us.msi.com/Desktop/Aegis-R-13th/Specification
Intel B760 is described as budget-minded, not high-end like the Intel Z790.
So, for someone looking to modernize their computer setup, without having to upgrade this or that, I see it as a good buy. But, for me, if I ever buy a new computer, the first thing that always gets upgraded is the memory, because they always build them on the low end, so they can sell them cheaper.
I just had a chat session with the MSI support staff and was able to confirm that the motherboard has 4 memory slots and only two are used to provide the 32 GB of RAM that ships with the computer. So, I have two slots to fill as desired/needed. :)
Besides increasing your RAM, you might consider more storage, as the DAZ content directories can get HUGE (mine is > 560GB), and that is not including my scenes and renders. Plus remember that you will also need backup space somewhere. I think your Power Supply will be fine as newer generation cards tend to have decreased power reqirements. What kind of cooling does your prospective system have - air or liquid? Keeping your components cooler will increase their lifespan, which is why I prefer liquid cooling. I think you are getting good "bang for buck", especially with the 2yr warranty, but you might consider shopping around and seeing what else is out there.
So you watch the market like I do. TIme for me to start looking for upgrades to mine. Enjoy your new system, jjoyner!!
