UE5.4 - Daz to Ureal (2024)
sgvsfgs13fsgvsfgs13f Posts: 11
edited March 2024 in Unreal Discussion
Unreal Engine 5.4 released last week, but the old plugin doesn't work. Unreal will not open if you try to use it!
Please update!
Post edited by sgvsfgs13f on
  • The current 5.4 release is a preview, not a full release. David has immediately updated the plugin on hit GitHub repo, if you "must have" that functionality now, download the latest version of the bridge here: https://github.com/David-Vodhanel/DazToUnreal/releases
    I'm sure that as soon as the full release of 5.4 is released, the team will update the version in Install Manager.
  • Plugin 'DazToUnreal' failed to load because module 'DazToUnreal' could not be loaded.  There may be an operating system error or the module may not be properly set up.
    what is the problem?
  • Unreal Engine 5.4 has officially released, but I am unable to select Unreal Engine 5.4 in DazToUnreal, why hasn't this been updated, because the version is fully released now.
  • I see that, but is that on Daz's end though?
  • superlativecgsuperlativecg Posts: 147
    edited April 2024
    I downloaded DazToUnreal.2023.1.2-UE54-win64-project-plugin.zip, extracted it, and placed the DazToUnreal folder into \UE_5.4\Engine\Plugins but I'm getting this error when I launch a project.
    "Plugin 'DazToUnreal' failed to load because module 'DazToUnreal' could not be loaded.  There may be an operating system error or the module may not be properly set up."
    Post edited by superlativecg on
  • @Superlativecg Here,... https:// github.com/David-Vodhanel/DazToUnreal/releases click on "DaztoUnreal" download and extract it, choose 5.4 or 5.3 (whichever engine you use), take that and drag n drop it into your Engine plugins folder, and be sure to put it in the "Marketplace" folder
    Thank you majestic!  That worked!
  • I'm also struggling to get things working in UE5.4. I've got the plugin correctly installed in UE as it seems. I've updated the dll from https://github.com/daz3d/DazToUnreal/releases/tag/2023.1.2-UE5.3-hotfix-1 into my DAZ folder, but when loading DAZ I have still no option to select UE5.4 as export version. Anyone knows how to fix this?
    306 x 248 - 17K
  • @majesticcreations where is the marketplace folde?
  • I'm having the same issue, I can't select version 5.4 . I think we just gotta wait a week or two for the updates to go live in the daz downloader,
    I shouldn't have deleted my project leveling down to 5.3 (which failed). We just gotta be patient.
  • scot_d87f45bc02scot_d87f45bc02 Posts: 1
    edited June 2024
    You might have to just create one if you've never added a Marketplace plugin to this version of Unreal yet.
  • Since there is still no 5.4 option, I have to resort to re-installing UE5.3, imported into UE5.3 and then migrate the asset to my UE5.4 project.
  • GordigGordig Posts: 10,613
    I've had success with the latest version on David Vodhanel's GitHub with 5.4.
  • @Gordig I still don't see an updated dzunrealbridge.dll which is what we need to get the 5.4 option in the drop down menu in DAZ Studio.
    It's in the Resources folder, but you can also just copy the entire folder into your DS and Unreal plugins locations.
  • Thanks Gordig!  I totally forgot about that.  I was looking on this page because the installation instructions neglect to mention that other location where I can find it.
  • version 5.4 of Unreal Engine doesn't show up when I choose the engine on daz to unreal. Also, the animation retargeting G8IK retarget doesn't show when in the animation blueprint on version 5.3 of Unreal. If you could help with any of these issues I am having I would appreciate it.
  • okso, how to install the 5.4 update from Github after the download?
  • I downloadet in github from david for ue 5.5 and Its working fine but I have a problem when I try to package the project.
    Packaging (Windows): LogLinker: Warning: [AssetLog] D:\New folder (2)\Plugins\UE_5.5\DazToUnreal\Content\Retarget\G9IKRig.uasset: Asset has been saved with empty engine version. The asset will be loaded but may be incompatible. PackagingResults: Warning: [AssetLog] D:\New folder (2)\Plugins\UE_5.5\DazToUnreal\Content\Retarget\G9IKRig.uasset: Asset has been saved with empty engine version. The asset will be loaded but may be incompatible.
    and when I go to play the game all of the character texture are black!
  • a-visiona-vision Posts: 5
    You don't need the exact plugin version for the transfer to work. Whenever you want to use Daz to unreal: In the daztounreal pop up window, at the very bottom, make sure you select the daztounreal destination folder in your unreal engine project (You can actually just create one yourself in your unreal content folder) and make sure the plug in is enabled in unreal engine (The plugin VERSION DOES NOT MATTER) I never select the plug in version in the daztounreal pop up window. All that matters is that the destination folder is selecfed and that daz and unreal are both open.
    615 x 187 - 14K
