What causes morphs with (3) numbers in parentheses and how do I fix it
What causes this to happen and what can I do about it?
  • Richard HaseltineRichard Haseltine Posts: 111,192
    In the Parameters pane option menu>Preferences (the lined button in the top corner) uncheck Consolidate Proerpties and you should see three sliders with the same label, you can then edit them in Parameter Settings so they are distinct.
  • crosswindcrosswind Posts: 10,191
    You've checked the option of Consolidate Properties, so the properties with the same Labels are consolidated....
    548 x 776 - 45K
  • evilded777evilded777 Posts: 2,543
    Thanks, Richard.
