How to convert G2F poses to G8F without messing everything up
Magic Dragon 3D
in The Commons
Hey guys! I bought DJ-Equipments on Daz Shop a few weeks ago, because I'm constructing a scene that will take place in a nightclub, but as these are older assets, I wanted to know how I could convert the DJ poses that come with this product designed specifically for G2M and G2F for G8M and G8F! Does anyone knows of a plugin that converts poses from Genesis 2 to Genesis 8?
https://www.daz3d.com/bone-minion-for-genesis-2-poses-for-genesis-8-and-81
Very easy to use, with easy to understand manual accessible from within DS. Female and Male are in the package. If you like it, there is a whole line converting from or to every generation from M4/V4 to G9.
Very easy to use, with easy to understand PDF manual accessible from within DS. Female and Male Minions are in the same package. It will do hierarchical poses with props as well.
If you like it, there is a whole line converting from & to every generation from M4/V4 to G9.
You can also check the freebie forum for some converters, quite a few in fact.
Though I'm also a Bone Minion user but I found this freebie converter works really great - https://www.renderosity.com/freestuff/items/93661/genesis-1239-pose-converter-for-genesis-8
Okay, pls follow the screenshots attached down below.
Well, if you can't get that to work, I have done a very simple pose transfer script, that takes a pose applied to a G2F figure and applies it to a G8F/G8.1F figure, here: https://www.renderosity.com/freestuff/items/89255/g2f-pose-transfer-to-g8f. It's a bit less convenient to use as you need G2 to be in the scene with the pose, but it's OK for one pose at a time.
Regards,
Richard.
Thanks for everyone's help! I bought the Bone Minion yesterday and was able to convert the DJ poses from the G2F to the G8F without any problems. It was very simple and exactly what I needed! Now I just need to figure out how the hell I'll be able to remove the Bone Minion's skeletons since they show up in Iray Mode when I render my scene lol
Select Bone Minion, in Parameters pane, turn off Show Bones.
I deleted the Minion Bone skeletons instead. Is there a problem?
No problem... only if you want to apply another G2F pose preset, you have to load Minion onto the figure again...
Another solution is to pretend it was a render happening in the 80s' when they wanted to add crude 3D everywhere
