Mirrors in iRay
petes imagespetes images Posts: 213
hi all
can anyone help with renders in iRay, my mirrors won't work and the speed is soooo slow, attached is a simple test render the result of one that took just under 60 mins using Summer with Leyton Hair, no lights as I have tried it with lights using cpu or my GeForce GT 640
Thanks in anticipation
Post edited by petes images on
    I don't know for sure, but I imagine that Iray works like any other render engine in this resepct.   Your figure is well lit from the rear, but it is the front that is facing the mirror, and so is not lit very well at all.   You will need to get some light onto your figure which comes from in front of the figure, or there is nothing much to reflect.
    I just tried this, and what would really help, is an Iray shader like Chromium, or a polished surface for the glass.
    What are you using for the refective surface?
  • fastbike1fastbike1 Posts: 4,083
    edited July 2015
    I think your shader isn't working for Iray.
    Here's a quick test. I created the mirror from a plane primitive and applied the "Car Mirror" shader in the Iray Car Paint shader set from Tom2099 on DeviantArt. No light except the default Environment (Dome and Scene).
    90% Convergence, 3 Minutes 40 seconds.
    JimmyC is right that you really want some light on the side of the character facing the mirror. Same as real world.
    750 x 1125 - 399K
    Post edited by fastbike1 on
  • petes imagespetes images Posts: 213
    Hi Al
    Thanks for the help, got it working now, Tom2099 shaders are excellent smiley
    FWIW, Aaron575 also has a decent mirror shader  on DeviantArt.
  • Thanks for the tip.
    I believe that the Aaron575.deviantart.com account is no longer active.
    Kindly,
    Grant
    Hi
    No it isn't sad
    pete
