MMX Genesis 9 Clones Questions
How does this product work: https://www.daz3d.com/mmx-genesis-9-clones-for-all
Do the clones become part of the autofit process? Or, are they stored in the G9 main folder, and I would have to click on a particular clone before I started to add outfits and hair?
  • LeanaLeana Posts: 13,536
    You'll get a new entry for "source figure" in the list in autofit dialog.
  • inquireinquire Posts: 2,464
    @Lena: OK, great. Thanks very much.
    If its helpful, this is a screen shot of the PDF that comes with the product
    762 x 616 - 65K
    Thank you very much.
  • LyoneLyone Posts: 139
    Hi there,
    I'm a vendor. I've created some clothes for G9 that I would like to convert to G8. Let's say I use MMX Genesis 9 Clones for that.
    Can I sell the altered G8 outfits after using MMX Genesis 9 Clones to convert my garments into G8?
  • crosswindcrosswind Posts: 10,304
    edited March 2024
    Lyone said:
    Hi there,
    Yes, you can. Actually users are also able to make Clones...so no limitation...
    Post edited by crosswind on
    Lyone said:
    Hi there,
    I believe so because you are not selling the clone shape I made.  Just a converted clothing item.  I imagine you will need to tweak the clothing after the initial fit anyways
  • pixelquackpixelquack Posts: 421
    edited November 2025
    Mattymanx, particular reason this info is not in the product page description?
    Post edited by pixelquack on
    Do I have to save G9 items fitted to G8 as props to not save the entire mesh each time I save the scene?
  • felisfelis Posts: 6,536
    When you have autofitted something, you should save it as a new figure/prop asset first.
    If you just save a scene file, that will else have to include at the data for the autofitted item.
  • Richard HaseltineRichard Haseltine Posts: 111,546
    f it isn't an item you expect to ruse then leaving it embedded n the scene file might be better than cluttering the data folder up with stuff that will not be referenced, but for items that are moderately likely to be reused it probably is worth saving as a support asset (File>Save As>Support Assets>Figure/Prop Asset)..
