• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic not merging geo grafts correctly
josiahmora20josiahmora20 Posts: 83
March 2024 edited March 2024 in Blender Discussion
I have a problem when using Golden Palace and STX nipples & navel on my genesis 9 character (victoria 9 skin) and trying to import into Blender via Diffeomorphic. I can't figure out why the grafts don't merge correctly. They seem to both leave a seam as well as have slightly off colors on the grafts.
This is how I set them up in Daz:
- Added Golden Palace "Smart Vanilla"
- Clicked Golden Palace "copy material script" now it has skin and looks correct
- Added STX navel and nipples (independently)
- Clicked STX Copy materials script (which doesn't work because Golden Palace messes it up).
- Took me a while but I fixed all materials by selecting the majora and minor SHELLS as well as the navel and nipples OBJECTS in scene then clicked the fix shell Omni script in Golden Palace
- Everything looks correct in Daz now
Things I've tried to get it into Blender via diffeo:
- Selecting "Merge Geografts" through the Easy Importer dialog and additionally selecting "Merge UV Layers."
- Selecting "Merge Geografts" through the Easy Importer dialog and additionally de-selecting "Merge UV Layers."
- De-selecting "Merge Geografts" through the Easy Importer dialog and then going to the finalize tab and trying to merge after import
What's going wrong? and is there a way to just bake the grafts into the mesh in daz before hand?
Update:
I tried creating a new project and only loaded Golden Palace this time. I used material script from golden palace and it is correct in Daz. Diffeomorphic did that exact same thing to the graft.
Diffeomorphic version 1.7.3
Blender Version 4.0.2
Post edited by josiahmora20 on March 2024
  • josiahmora20josiahmora20 Posts: 83
    Welp.. I fixed the problem through trail and error.. It apears to be a bug where every new project you have to re-load the root path in Blender then import it works, merging geografts with the mesh correctly.
    Anotrher thing, my origanl method to make both grafts and shells work was ineffective and that original project file still refuses to load correctly. So for anyone struiggling with this here's exactly what I did in Daz to get it to work:
    - Add the Victoria 9 skin to genesis 9
    - Add STX navel and run mat script
    - Add STX Nipples and run mat script
    - Select Genesis 9 in scene and add a Golden Palace smart preset
    - Go to the shells in scene tab for majora and minora and for each go to parameters>shell>visibility>surfaces and turn off stx gen 9 nipples and navel (both)
    -Select Golden Palace int he scene tab and run the Golden Palace material copy script.
  • PadonePadone Posts: 4,034
    March 2024
    For shells I added a note in the docs to explain the limitations.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Global/Meshes
    March 2024
    Good deal!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
