render with LuxCore I get the Yellow Screen with 1's
Fettbemme
Is there a tutorial to get started with LuxCore Render/Luxus ?
I get the yellow screen, no matter what I try.
The only thing working is the sample scene
Hope that pdf files here help.
(source carraracafe.com)
Thanks
one question is luxrender.net gone?
I get from the PDF link this
Look on the date in the PDF files.
Lux you can find here > https://luxcorerender.org/
And maybe here (but not sure) > https://www.3d-board.de/downloads/category-file-list/279-carrara-deutsch-manual-shortcuts-languagepack/
ah, yep
just noticed
thanks
If you are using Luxcore, then a yellow screen means either there are no lights, or, an incorrect material used. Run Luxcore IPR (Assemble room > edit > Luxcore IPR) which will give error message.
If you are using Luxus, then have you installed luxrender standalone? https://wiki.luxcorerender.org/Previous_Version
Thanks
I think it's OK now
