Applying Makeup to G9 UV on G8.1? SOLVED
xyer0xyer0 Posts: 6,409
edited March 2024 in The Commons
Hi all. I've been unsuccessfully trying to apply various makeups (Angela 9, Victoria 9, etc.) to a G8.1F character that is using G9 UVs for G8 & G8.1F. I'm selecting both the figure and the geograft, but I'm getting no visible makeup on render. Does anyone know the trick?
Post edited by xyer0 on
  • crosswindcrosswind Posts: 9,749
    edited March 2024
    You have to rename Head and Face surfaces before run G9/V9 Makeup scripts...
    With Geometry Editor - Tool Settings pane, rename Head to HeadBack, Face to Head. Select G8.xF, run a Makeup script, then copy Head surface to Lips surface.
    2560 x 1400 - 2M
    Post edited by crosswind on
  • xyer0xyer0 Posts: 6,409
    edited March 2024
    Thank you, @crosswind, I'll do that now.
    I tried to edit the surface name by Create Surface from Selected, couldn't undo, had to reload. G8F loading is still a slow process after issues with Turbo, yada, yada. Looked up instructions on renaming surfaces.
    Renaming surfaces found here and below:
    Go to tools -> geometry editor then window -> panes -> tool settings
    in the tool settings tab you can double click a surface name and it will let you edit it :)
    Thanks so much, @crosswind, for your prompt help!
    Great!You're welcome.laugh
