Applying Makeup to G9 UV on G8.1? SOLVED
xyer0
Hi all. I've been unsuccessfully trying to apply various makeups (Angela 9, Victoria 9, etc.) to a G8.1F character that is using G9 UVs for G8 & G8.1F. I'm selecting both the figure and the geograft, but I'm getting no visible makeup on render. Does anyone know the trick?
Post edited by xyer0 on
You have to rename Head and Face surfaces before run G9/V9 Makeup scripts...
With Geometry Editor - Tool Settings pane, rename Head to HeadBack, Face to Head. Select G8.xF, run a Makeup script, then copy Head surface to Lips surface.
Thank you, @crosswind, I'll do that now.
I tried to edit the surface name by Create Surface from Selected, couldn't undo, had to reload. G8F loading is still a slow process after issues with Turbo, yada, yada. Looked up instructions on renaming surfaces.
Renaming surfaces found here and below:
Go to tools -> geometry editor then window -> panes -> tool settings
in the tool settings tab you can double click a surface name and it will let you edit it :)
Thanks so much, @crosswind, for your prompt help!
Great!You're welcome.
