Can I make makeup script for genesis 9 characters?
Hi, everyone,
I'd like to make makeup for my custom character to add and remove them as needed
but I don't know how to do it.
I want to create scripts like makeup in Voctoria 9, is there a way to do that?
Thank you...
Post edited by AsabA on
Technically, yes, but you have to know Daz Script... Generally speaking ~
1st, just like the Layered Image Presets of this product (under the path: /data/Daz 3D/Genesis 9/Base/Tools/Script Loads/V9 Makeup/...), you need to save Layered Image Presets of the makeup you created.
2nd, there're Scripts with G9 Starter Essentials ( under the path: /data/DAZ 3D/Genesis 9/Base/Tools/Utilities/...) . You need to call those DSE(s) in your Script to remove LIE on Makeup mappable slots of Head surface with PBRSkin, then apply Layered Image Presets accordingly.
If you set multiple Layeres with LIE, each Layer has to be handled separately within your Script, as well as the order of Layers and required properties related to Makeup on Head surface.... It's certainly doable with Daz Script but not really an easy job, as per my exp. of script.
Thank you for the answer.
I think I understand how it works now.
I wish I could see the contents of the scripts.
But your answer is very helpful.
Thanks again.
