Can I make makeup script for genesis 9 characters?
AsabAAsabA Posts: 24
edited March 2024 in Daz Studio Discussion
Hi, everyone,
I'd like to make makeup for my custom character to add and remove them as needed
but I don't know how to do it.
I want to create scripts like makeup in Voctoria 9, is there a way to do that?
Thank you...
596 x 536 - 423K
Post edited by AsabA on
  • crosswindcrosswind Posts: 10,356
    Technically, yes, but you have to know Daz Script... Generally speaking ~
    1st, just like the Layered Image Presets of this product (under the path: /data/Daz 3D/Genesis 9/Base/Tools/Script Loads/V9 Makeup/...), you need to save Layered Image Presets of the makeup you created.
    2nd, there're Scripts with G9 Starter Essentials ( under the path: /data/DAZ 3D/Genesis 9/Base/Tools/Utilities/...) . You need to call those DSE(s) in your Script to remove LIE on Makeup mappable slots of Head surface with PBRSkin, then apply Layered Image Presets accordingly.
    If you set multiple Layeres with LIE, each Layer has to be handled separately within your Script, as well as the order of Layers and required properties related to Makeup on Head surface....  It's certainly doable with Daz Script but not really an easy job, as per my exp. of script.
  • AsabAAsabA Posts: 24
    edited March 2024
    Thank you for the answer.
    I think I understand how it works now.
    I wish I could see the contents of the scripts.
    But your answer is very helpful.
    Thanks again.
