Glowing Effect
Electro-Elvis
I created this "Ring of Fire" with the Ivy Generator. Now I wonder, if it is possible to add a glowing effect? Any ideas are greatly appreciated.
Post edited by Electro-Elvis on
Electro-Elvis - very nice "Ring of Fire". Four years ago I made a render with a glowing Bryce tree (below upper part). The material used (below lower part). It shows the the leaves texture (green), and for the trunk it is the same, just channel A is different, shown at left (brown).
It is only lit by specularity amplified with a phased hyper texture (PHT) in Ch D. The specular comes from an HDRI with a dynamic range of around 2700:1, Specularity 300 and HDRI Effect 0. The sun in the example is behind the tree, also with Specular 300 and Diffuse 0.
I got the idea for the example render from here: https://horo.ch/docs/mine/pdf/Spec-to-TA-Light.pdf
If you have not made a PHT, here is how it is done in a minute or two: https://horo.ch/docs/mine/pdf/PhasedHT.pdf
I forgot to mention the render settings. Please see below. Rendering takes a bit of time. Another important detail: Even if there is no HDRI Effect, True ambience optimization must be disabled (arrow right of HDRI Effect).
Electro-Elvis awesome ring of fire. Thanks for mentioning the Ivy Generator.
Horo lovely glowing effect
Electro-Elvis : very well done ring of fire.
Horo : fantastic glowing effect.
Thank you mermaid and adbc. I made it on 24 April 2004 - it's been a while...
Horo, mermaid010, adbc: Thanks a lot. I will try out your hints as soon as I have a bit more time.
Nice effects, Elvis and Horo
Awesome effect Horo and Electro! This should be a challenge.
