Glowing Effect
Electro-ElvisElectro-Elvis Posts: 936
edited February 2024 in Bryce Discussion
I created this "Ring of Fire" with the Ivy Generator. Now I wonder, if it is possible to add a glowing effect? Any ideas are greatly appreciated.
Ring of Fire
Post edited by Electro-Elvis on
  • HoroHoro Posts: 11,456
    Electro-Elvis - very nice "Ring of Fire". Four years ago I made a render with a glowing Bryce tree (below upper part). The material used (below lower part). It shows the the leaves texture (green), and for the trunk it is the same, just channel A is different, shown at left (brown).
    It is only lit by specularity amplified with a phased hyper texture (PHT) in Ch D. The specular comes from an HDRI with a dynamic range of around 2700:1, Specularity 300 and HDRI Effect 0. The sun in the example is behind the tree, also with Specular 300 and Diffuse 0.
    I got the idea for the example render from here: https://horo.ch/docs/mine/pdf/Spec-to-TA-Light.pdf
    If you have not made a PHT, here is how it is done in a minute or two: https://horo.ch/docs/mine/pdf/PhasedHT.pdf
    Example4EE
    I forgot to mention the render settings. Please see below. Rendering takes a bit of time. Another important detail: Even if there is no HDRI Effect, True ambience optimization must be disabled (arrow right of HDRI Effect).
    RO4EE
    640 x 1020 - 173K
    663 x 347 - 45K
    Post edited by Horo on
  • mermaid010mermaid010 Posts: 6,118
    Electro-Elvis awesome ring of fire. Thanks for mentioning the Ivy Generator.
    Horo lovely glowing effect
  • adbcadbc Posts: 3,115
    Electro-Elvis : very well done ring of fire.
    Horo : fantastic glowing effect.
    Thank you mermaid and adbc. I made it on 24 April 2004 - it's been a while...
  • Horo, mermaid010, adbc: Thanks a lot. I will try out your hints as soon as I have a bit more time.
  • HansmarHansmar Posts: 3,166
    Nice effects, Elvis and Horo
  • NGartplayNGartplay Posts: 3,404
    Awesome effect Horo and Electro!  This should be a challenge.
