I could need a good/realistic looking Landscape Shadere Tutorial
FettbemmeFettbemme Posts: 319
edited February 2024 in Carrara Discussion
so far all landscape shaders look way too cartoonish
I could need a good/realistic looking Landscape Shader Tutorial
this looks terrible
PS.: I havent seen a Gardening Ad so far … LOL
Post edited by Fettbemme on
  • DiomedeDiomede Posts: 15,401
    I hope this thread helps.  Unfortunately, some of the links are no longer active.
    https://www.daz3d.com/forums/discussion/63528/carrara-terrain-questions
    This video is on terrain shaders.
  • Bunyip02Bunyip02 Posts: 9,288
    To obtain photo-realistic ground I use a combination of photo/pbr textures (Flinks at Renderosity does some good ground ones) with Philemo's Triplanar plugin.
    Only problem with it is on large terrains you can get repeating pattern look.
    https://www.daz3d.com/forums/discussion/166396/new-plugin
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,473
    I fix my large terrains with lots of mix operators and layers
    DCG shoestring shaders Supermixer is good too
  • FettbemmeFettbemme Posts: 319
    Thanks for your help
    I did this for now with a PBR approach, but really wanna get into the Shader Editor which seems actually rather powerful
    2000 x 844 - 2M
    A few tutorials that I have collected off the web
    pdf
    pdf
    Carrara Landscapes tutorial1a.pdf
    3M
    pdf
    pdf
    Carrara terrain0tut.pdf
    410K
    pdf
    pdf
    Carrara terrain1tut.pdf
    222K
    pdf
    pdf
    Carrara terrain2tut.pdf
    568K
    thanks
    lot to do now
    cool
