• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Basic Morph Settings Import/Export One More Time?
DiomedeDiomede Posts: 15,410
February 2024 edited February 2024 in Blender Discussion
I am sure this has been asked a thousand times, and I have watched at least three Youtube videos, but I am still getting a scrambled mesh when I try to do a simple morph to a base G8F figure using OBJ export and OBJ import.
- Open Daz Studio.  Load G8F.  Delete eyelashes.  Set mesh resolution to base.  Export OBJ.  Choose Daz Studio preset.  Export at 1%.
- Open Blender.  Import G8F.  Edit to make a morph, in this case simple nose change.  Export OBJ.  Make sure check box for vertex order.  Export at 100.
- Return to Daz Studio.  Select G8F.  Edit OBJ, start morph loader pro.  Use Daz Studio Preset.  Select morphed obj.  Set deltas only.  Morph is 'successful.'  Yay.
- Find new morph in parameters tab.  Start dialing up.  Mesh is yucky.  Oops.
*** - What export settings from Daz Studio?  Import settings in Blender?  Export settings in Blender?  Morph loader pro settings?  For simple figure morph like this Cyrano nose morph?
Post edited by Diomede on February 2024
  • stem_athomestem_athome Posts: 526
    February 2024
    Hi,
    From Blender, export at scale 1 (not 100)
    In morph loader, select use From "Cinema 4d (i unit = 1m)
    Should then work OK.
  • felisfelis Posts: 6,124
    February 2024
    Based on the image it doesn't look like a scale issue.
    How does it look if you just activate the morph slightly?
    It does look like an issue with vertex order, but I can't see how it should come.
    (Neweat cersion of blender have changed the obj exporter, so vertex order is no longer an option (it is always on).)
  • crosswindcrosswind Posts: 9,733
    February 2024
    Was there any Modifier added?  Uncheck Apply Modifiers when export...and try again.
    Besides, you're using Blender 3.x, don't use import / export Wavefront (.obj) (legacy), use Weavefront (.obj) instead.  (legacy way of OBJ is discontinuted in Blender 4.x). Then when exporting OBJ from DS, keep default 100%, when importing / exporting in Blender, always use 1%.
  • DiomedeDiomede Posts: 15,410
    February 2024
    Thank you each.  First take away seems to be that I should address having an old version of Blender installed on my laptop.  Will install version 4.  Then I will follow advice on scale.  yes
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
