• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic - How to export animation?
«12»
  • crosswindcrosswind Posts: 9,564
    February 2024 edited February 2024
    James said:
    @crosswind
    The FK IK snapping problem.
    https://prnt.sc/ugqmsas0V7bB
    This is a problem for me, when I want to work with IK and FK.
    Strech is 0
    Limit is unthick.
    The last problem I mentioned was still all in Blender environment.
    About the feet and arms that can't stay put, I try to recreate it again.
    Ah, I saw the moving which I also encountered the similar issue. Pls try ticking Pole Targets when rigging to MHX, which can enable perfect FK/IK snapping.
    https://mega.nz/file/iPQASQIA#iT8FTENyNl8gDNalwkJ9riuLA8VT8YSLwd_IgyaeIp4
    Post edited by crosswind on February 2024
  • PadonePadone Posts: 4,015
    February 2024
    @James I can't reproduce the issue with snapping, it works fine here. You may need to update since I recall this issue was solved a while ago. The actual MHX version is 1.7.4.0111.
    February 2024
    The snapping issue can be easily reproduced with default MHX rig with no Pole Targets activated...
    February 2024
    Nope, tried without poles and works fine here.
    my steps:
    1. import G8F and convert to MHX
    2. pose the hand with the IK control and keyframe
    3. snap FK to IK then IK to FK multiple times, nothing moves
    my steps:
    Thanks, that was my key finding as well... but pls try with G9 in Blender 4.0+ if possible.
    Here's a quick video - https://mega.nz/file/KaAQFAgA#7f8COWa3s74S2ZlOCTl2qXGoMeY9dZF2KEmfV4mdrWQ
    Actually even with G8F/M, there's very subtle change when toggling Snapping or FK/IK, easy to overlook...
  • JamesJames Posts: 1,145
    @Padone
    Here's an example how I recproduce it from the rig > convert > posing > snapping problem
    blob:https://giphy.com/e5693e30-8451-44c7-9693-9b0a6aab7059
    (Please copy paste the urls including the blob word to see the gif)
    I use g9, MHX, no limit, no poles
    It seems up to certain point the bones will stop moving after awhile of snapping back and forth.
    It could be Padone can't reproduce the problem because there's certain situation, where the snapping wont show any problem.
    Post edited by James on February 2024
    Nope, G9 works fine here, blender 4.0.2 mhx 1.7.4.0111, or please describe the exact steps to reproduce the issue as simple as possible.
    my steps:
    1. import G9, then convert to MHX without poles
    3. snap FK to IK then IK to FK multiple times, works fine nothing moves
    update. It seems it's disabling limits with the MHX panel, while disabling in the global settings works fine. Reported to Thomas.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/1927/snapping-issues-with-mhx
    Post edited by Padone on February 2024
    @Padone
    I'm using blender 4.0.2
    MHX 1.7.4 (is it different from 1.7.4.0111?)
    The add on says the version is 1.7.4.
    I downloaded it from the repossitory.
    Which I think that should be the most updated commit.
    Here's the step by step How I did it.
    This time I use the leg.
    No need of a keyframe.
    (copy paste it, include the "blob")
    https://mega.nz/file/ovNSgDjR#F50aDLJpzrc3dDSFYlaBmi2LcuuK72Gl4gcEsseL2sw
    February 2024
    James said:
    @Padone
    I attached the video in above post of reproducing the issue you have in the same way. The issue really exists there. That was why Thomas added Pole Targets to assure perfect snapping I presume.
    February 2024
    James said:
    @Padone
    Your latest version numbers are correct. But your link shows no GIF or file...
    February 2024
    Do you include the blob?
    Don't just click it.
    Need to be copy pasted.
    It's a strange kind of a link, but I dunno, that's how the host provide the link.
    February 2024
    The address is stated as invalid if including blob. NP~ anyway I experienced the issue on my side.
    @crosswind
    OK, I've updated the link.
    The video is for Padone to see, the steps I took.
    Got it ~ thanks ! And thanks Padone for having reported the issue ! yes
    February 2024
    @Padone
    Anw, I tested to disable location and rotaition limits from  global settings, but the FK IK snapping problem still persist.
    Why sometimes the body  mesh could become totally mesh up when I import a pose?
    The bones pose correctly, but not the body mesh.
    https://prnt.sc/9k4dnfrZa7FP
    I loaded a scene where there are 2 figures standing in the center of a room in neutral A pose.
    One figure always bending like that, everytime applied a pose, the other is not.
    It looks like the mesh is not normalized, easy import does it by default. For example if you enter edit mode and move the mesh away from the armature then you get those "rubber" effects because the pivots are misplaced.
    update. I tried to easy import multiple G8 G9 figures together and it works fine here. However, importing each figure alone is recommended, especially for complex figures.
    287 x 261 - 16K
    Hemm, I did use easy import.
    Why it still behaves like that?
    Currently I have to easy import one by one, to prevent that. Each character, and then the scene.
    February 2024
    Base figure ? or custom figure ?
    February 2024
    both custom figure.
    February 2024
    Rigging of both custom figures have been adjusted to shape in DS?
    February 2024
    It's a DAZ store figures.
    I supposed it's adjusted.
«12»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
