• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic - How to export animation?
JamesJames Posts: 1,145
February 2024 edited February 2024 in Blender Discussion
Diffeomorphic - How to export an animation?
I baked it to FK Rig.
I saved it as pose preset.
But, when aplied it to a character the animation just wrong.
Post edited by James on February 2024
«12»
  • crosswindcrosswind Posts: 9,552
    February 2024
    I've tried it with MHX but also failed to save a correct Pose Preset... Let's see if some experienced guy can help with it.
  • JamesJames Posts: 1,145
    I think it's not just MHX but also the others
    @ThomasLarsson
    Hi, Thomas could you lend us your hand with your add-on?
    I'm using the latest 1.7.3 and Blender 4.0
  • PadonePadone Posts: 4,003
    reported to Thomas
    https://bitbucket.org/Diffeomorphic/import_daz/issues/1923/export-doesnt-seem-to-work
    update. Thomas fixed it with the latest commit, you need to update both the importer and the exporter.
    Post edited by Padone on February 2024
    February 2024
    @Padone
    I was using G9 by the way.
    @Padone
    How to update the importer and exporter using the commit?
    I'm confused.
    There's no download button to download the file,
    also I can't find this code:
    elif self.trgRig:
    in my current animation.py fil e.
    That's great ! Thanks !
    @James  You download the latest commit version in here: https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    Remove the older version in Blender and install the above ZIP, and check this as well : https://bitbucket.org/Diffeomorphic/import_daz/commits/c400c95d0ec9163de963c8eca7dfccfb9c0a7ec6
    Download exporter in here: https://bitbucket.org/Diffeomorphic/export_daz/downloads/
    Post edited by crosswind on February 2024
    Okay, but... the "Save pose as preset" button seems gone now...?
    https://prnt.sc/fDOcR3XOjXI-
    I'm confused on how to use those. Do I suppose to check each of those files and replace each code manually?
    I got errors when trying to activate it.
    https://prnt.sc/lplK6dWXgAuA
    You have to change the module name first before installation, as below.
    Then install / activate Importer package first, then Exporter package.
    I just tested a case, it works now.
    1615 x 853 - 88K
    881 x 1248 - 197K
    Okay,
    Installation works on my side.
    On your side does saving pose by using MHX work now?
    I still can't get it work.
    Snap FK all also result errors (basically all snaps result errors)
    https://prnt.sc/62cBJwOJvU35
    Yes, with MHX + imported Action from DS and some change in Blender, then I just Baked to FK and Saved as Pose Preset. Apply the Preset to G8 in DS, it worked with correct animation result.
    February 2024
    Does Genesis 9 works too?
    Is the snapping of bones pops errors on your side?
    I can't get it work on G8F too.
    Where did I do wrong.
    My steps:
    1. In blender I import a figure by using easy import.
    2. covert the rig to MHX
    3. Move a hand IK bone.
    4. locrot.
    5. move to the frame 20
    6. Move the hand IK bone again to somewhere else
     7. locrot.
    8. Bake Pose to FK Rig.
    9 Save Pose Preset.
    Save it to a file.
    10. On DAZ click a figure.
    11. Apply the pose preset.
    Nothing happened.
    With a G9, it also works. No error on my side when Snapping FK/IK... Have you updated MHX Runtime? Latest version is 1.74
    https://bitbucket.org/Diffeomorphic/mhx_rts/downloads/
    1751 x 1395 - 443K
    Ok, I've updated the MHX to 1.74.
    Now, works ok.
    But now the Bake Pose to FK Rig not working.
    It just simply won't bake. No keyframes were made.
    I tried many times.
    For the test, you better import an Action or make an animation with the rig first... Bake to FK makes no keyframe if the timeline is empty...
    No need to change module name of MHX...
    I made an animation. I move the left hand.
    The timeline has two keyframes. One on frame 1, the other on 20.
    @Padone
    Why I can't Bake Pose to FK Rig?
    If so, you firstly Transfer IK to FK on MHX panel - Animation (arms / legs separately), then bake and Save as Pose Preset. I tested it in this way, it worked.
    1091 x 1165 - 205K
    Ok, it works.... GOSH.........................
    I've been pulling my hair.
    Thank you so much.
    It seem after Transfer IK to FK,
    the baking unnecessary anymore.
    As if the transfering process is a baking process.
    I saved the pose preset, and still works.
    Thank you so much.
    Yea, you're right! Haha~  Thanks to Thomasyes
    Yes, thanks also  to thomas and Padone.
    @crosswind
    another topic.
    Do you experience a bit of bones movement, each time snapping from IK to FK, vice versa?
  • benniewoodellbenniewoodell Posts: 1,999
    February 2024
    When you say arms/legs separately, am I supposed to highlight the arms and run the transfer, and then highlight the legs? I've always been so confused with this and now that I'm seeing that folks are getting MHX to work back to Daz, I'm excited to try again! Thank you for any input!
    February 2024
    James said:
    @crosswind
    another topic.
    Yes, with Limits checked, as well as depending on the poses... You may try unchecking Limits in MHX and Snap again.
    Oh... sorry ! We can do Transfer with arms / legs both checked !
    February 2024
    @crosswind
    is the the applied animation (pose preset) in DAZ sometimes not as exactly as worked in blender ?
    I'm having the issue.
    James said:
    @crosswind
    After transferring to FK, saving the preset and loading it back to the figure in DS, the animation result should be the same. As far as I tested, I've seen no difference yet. Maybe the result of some corrective morphs vary...
    Pls try transferring to FK with Arm / Legs / Spine checked at the same time.
    February 2024
    A little explanation that may help.
    1. installation. In the latest commits Thomas splitted some code, so you now need to get and install the modules separately.
    https://diffeomorphic.blogspot.com/2024/02/add-on-split.html
    2. bake IK to FK. To export a pose preset you first need to bake IK to FK, this is done in the MHX panel as it's usual with custom rigs. For example rigify is the same and has its tools for baking.
    https://bitbucket.org/Diffeomorphic/mhx_rts/wiki/Animation
    3. exporting poses from blender to daz. When exporting from blender to daz always keep in mind that a daz pose is FK, while in blender you use a IK rig. This means for example that if you use stretchy limbs they will not stretch in daz studio, also IK limits are different so you need to turn off the limits in daz studio.
    @Padone
    Another problem I'm having is, when I use IK in blender, I can lock hands/feet on the same spot exactly, and made an animation.
    But when I snapped the IK bones to FK bones, the animation result, they won't stay at the same spot anymore.
    As if the translation of bones from IK to FK can't be 100% correct.
    Is this something that's inevitable?
    I just want to keep my expectation straight.
    Also if keep snapping back and forth IK to FK, for example left arm, the arm starts to move to a certain direction.
    Because on each snap, it seems the rotation value of I don't know which bones, add up/keep changing.
    February 2024
    Have you tried zeroing stretch weight as well as cancelled Limits in MHX ?
    Or you attach the saved Pose Preset here, we may try to test.
    @crosswind
    The FK IK snapping problem.
    https://prnt.sc/ugqmsas0V7bB
    This is a problem for me, when I want to work with IK and FK.
    Strech is 0
    Limit is unthick.
    The last problem I mentioned was still all in Blender environment.
    About the feet and arms that can't stay put, I try to recreate it again.
«12»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
