Add a note
Let's say you have a Daz item of clothing and you want to add a reminder note to the clothing icons about there being related prop items too. How do you do that?
  • barbultbarbult Posts: 26,447
    You could replace the ".tip" file with an image file that you created containing the text of the note.
  • or if there isn't a tip file add one - filename.tip.png, 256 pixels square. You could also add a tag (e.g. Has Props) by selecting the files and entering it in the Tags area at the bottom of the content pane - it is, I think, collapsed by default.
  • RandomRandom Posts: 236
    Thanks you both. That'll work.
