• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
How to rotate a certain area of a mesh (character lip)?
JamesJames Posts: 1,177
February 2024 in Blender Discussion
I want to make a character bites her lower lips. DAZ3d Genesis has no easy way to do it. So I want to sculpt it on blender.
But I can't find any tutorial showing how to rotate certain area of mesh (a lip).
How to do it?
  • felisfelis Posts: 5,970
    February 2024
    I would rotate it in modelling.
    Select one or more rows of faces on the lip, and then rotate with proportional editing enabled with a radius of maybe 2 cm, and set to connected only.
  • 31415926543141592654 Posts: 975
    February 2024
    Blender is more powerful and stable, but perhaps you should consider learning Hexagon as well. It is designed to work with Daz Studio (easy import and export) and it works great at making small morph changes like you are describing.
    Things to note: maker sure your model is zeored out when you send it over and back or strange things happen. Also, pay attention to the names as everything must stay the same for the morph to apply to the model when re-imported.
  • crosswindcrosswind Posts: 9,645
    February 2024 edited February 2024
    First, you can use FACS expression dials like Mouth / Jaw Open, Mouth Roll, Press, Purse, Shrug, Up / Down, etc.... or manipulate Lip sub-nodes under Lower Face Rig to easily get a "bite lip" expression. (like ss1)
    Well, making it in Blender is doable but will be cumbersome, especially for the case of manipulating Lips (as well as Jaw, mouth cavity moving... etc.) no matter with Edit or Sculpt mode... because making such a "bite lower lip" is not a simple "lip rotation"....you need to do it with Mask while having to make other partial parts "staying" or "moving" naturally with this expression. Then after importing back to DS, you may also have to check rigging, corrective morphs as well... blah blah blah.
    So better get to know FACS first of all, then try to well use them... At least you may dial some expressions first, fine-tune them in Blender and import delta back...rather than doing all from scratch. Then you'll get much better results, as well as pretty efficiently for sure.
    2021 x 1391 - 448K
    Post edited by crosswind on February 2024
  • JamesJames Posts: 1,177
    February 2024
    Hemmm... I'll try.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
