changing apocalyptic background with out starting a new scene
Dave_1043192Dave_1043192 Posts: 207
I just bought Apocalyptic Plant Outdoors Set 1 - Iray HDRIs which works very well except once I have chosen a backdrop I can not seem to change it for a different one from the other selections in Apocalyptic Plant Outdoors Set 1 - Iray HDRIs. I can not see how to delete the exsisting one and clicking on a different one will not change it .Only starting a new scene can I choose a different one Im sure i must be missing something any ideas please?
  • MusicplayerMusicplayer Posts: 515
    edited July 2015
    Hi,
    I also own this amazing set of HDRI's.
    When you click on the apocalyptic HDRI which is also your background scene, it automatically changes the HDRI in the Environment Map render settings.
    Render - Render Settings - Environment - Environment Map.
    Select the Environment map and remove it by choosing the option 'None' then go back into your content library and choose the new HDRI map/ background you want. Once selected, it automatically again puts it in the Environment Map section of the render settings.
    Hope this was the answer you required.
    Cheers.
    EDITED TO NOTE : Cameras from the previous loaded HDRI have to be removed from the scene via the scene tab before this will work. It seems both the new HDRI and its cameras need to load for the change to happen.
    Just tried this, to double check what I am saying is correct, and it works fine without needing to start a new scene.
    SECOND EDIT : Just played some more, and it seems that by just deleting the cameras from the previous HDRI scene in your scene tab allows you to click on a new HDRI set and it loads. So no need to go into the Environment Maps render settings as the change is automatic.
    Post edited by Musicplayer on
  • Dave_1043192Dave_1043192 Posts: 207
    edited July 2015
    unfortunately this is not working for me i deleted all the cameras set the enviroment to none like you said when I click on a different hdr i just get the same one back1 see my images to see whats happening for me
    As you can see start the scene , remove cameras , change enviroment to none , try to add night scene it only adds the cameras enviroment still shows the same on i started with
    1920 x 1046 - 729K
    1920 x 1041 - 812K
    1920 x 1041 - 724K
    1920 x 1042 - 868K
    1920 x 1037 - 902K
    Post edited by Dave_1043192 on
    edited July 2015
    Hi, Thanks for your screenshots.
    Sorry this did not work, there is another way which you may like to try.
    Say for example your scene has apocalyptic 01a as the lighting and scene....this has 3 cameras....and you want to change it to apocalyptic 03b Night :
    First delete out the 3 cameras from 01a in the scene and click on apocalyptic 03b Night set in your content library....four cameras will load into the scene.
    Next go to the render environment tab and left mouse click on the Environment Map and choose browse....this takes me to the apocalyptic HDRI folder.... Choose ApocNight-03b_hdr.hdr file and click "open"
    Your environment map will then change to the Apocolyptic Night 03b HDRI (for this example) and the background scene will change accordingly.
    You should then have the right background and number of cameras for your chosen HDRI.
    I do apologise for any confusion, and hope you have success with this method. I will post screen shots too, if required.
    Cheers,
    Great! that way worked many thanks for your help much obliged
  • Dumor3DDumor3D Posts: 1,316
    Hi and sorry to be so late into this thread. Yes, it's a little ragged doing this, but it seems this is how it works right now. However, there is one more way. Delete the cameras from the first set that was loaded. Load the new set you wish to try, then load the "Render" Environment with the matching name. Either way, via choosing the new HDR in the Environment Map settings or this method both work for me.
    Thanks for the compliments! I'm glad to hear you're enjoying the product. The photoshoots there were interesting to say the least. :)
