• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic - eyelashes not following face expression correctly
DissendiorDissendior Posts: 139
January 2024 in Blender Discussion
"Not correctly" means: I change the face expression of a character in Blender and the eyelashes start to poke through the head or they are slightly misplaced what gives the character a weird look.
  • Imported a character into Blender with Diffeomorphic
  • merged all rigs
  • I left eyelashes as an indiviual mesh (maybe this is not the way?)
    • Tested it with merged meshes but it seems to me that this doesn't solve the issue.
  • imported face expressions and other morphs to the character mesh and transferred the shape keys to the eyelashes (also: is that a good idea?)
  • adjust the face expression in Blender in the "Morphs" section of "Daz Runtume" and seeing the eyelashes slightly misplaced, parts get hidden by the head or they just look a little bit weird
  • it's not happening with all face expressions, some look like in daz, but some are slightly weird
What I've found is that my original character and the eyelashes in Daz still have morphs which I do not have in Blender yet. From the names of these morphs it seems that there are character specific morphs for some face expressions / face movements?! Could it be like that?
So do you face similar problems? How do you deal with that? Do you import all the other morphs as well or simply adjust the placement / mesh of the eyelashes in Blender?
  • PadonePadone Posts: 4,069
    January 2024
    It depends what you need. In blender it makes little sense to have gazillions of morphs all interacting each other, as it may be in daz studio for a mix of figures for example. Usually you bake the shape then import some standard morphs for animation, eventually adjusting them to your needs if necessary.
    Otherwise the way to go is to import all the morphs you use in daz studio, and transfer them. If you miss some morphs the results will not be the same.
  • DissendiorDissendior Posts: 139
    January 2024
    okay, but do I understand it right that there are this tons of morphs, sometimes for a specific character for specific poses and expressions?! what do you mean by "bake the shape"?
  • crosswindcrosswind Posts: 9,709
    January 2024
    If you wanna have more perfection in the case you mentioned, you have to import all the corrective morphs related to expressions (e.g. eJCMs, MCMs, cbs....) from the character products that you used on your customized character(s). Even, you have to fix some expressions in Blender if your character(s) are highly mixed or customized, then create shape keys for them. Technically, this is a much better way but way more complex as well.
    January 2024 edited January 2024
    By "bake the shape" I mean export as dbz. And yes, depending on the figure daz studio may really use hundreds of morphs, you can use the "baked correctives" option in easy import to get the exact custom figure morphs.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs/Import Baked Correctives
    Post edited by Padone on January 2024
    January 2024
    thank you both... this helps me a lot to understand more
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
