minimalist maxi dress outfit for genesis 81 females where is the boob shape coming from?
Pitmatic
in The Commons
Hi Guys
https://www.daz3d.com/minimalist-maxi-dforce-maxi-dress-for-genesis-8-and-81-females
The usual boob question when simulating this dress it appears to have its own boob shape built in, i would rather dforce just let the dress drape over the figues boobs and not rely on a hidden shape that is larger than my figure in this case Mirage 8.1( i have tried dialing out mirages body to use the base 8.1 figure but it still does it.)
Thanks In Advance
Yes, this dress seems designed for the char with big boobs... Anyway, you may try this way:
- 1st, retrieve dForce Modifier Weight : Select the Dress, Create - New dForce Modifier Weight Node...(ss1)
- Select the Weight Node, Alt + Shift + W. In Tool Settings, select Influence Weights, add more Sensitivity, Ctrl + Mouse Wheel to enlarge the cursor size. Then carefully paint the Weight in the related area to Red. (ss2)
- Simulate. (ss3)
Thank you @crosswind for your invaluble help sorry to be slow to respond we have been having a lot of powercuts due to the storms and remedial works.
No problem! Pls take your time, and take care!
