minimalist maxi dress outfit for genesis 81 females where is the boob shape coming from?
Hi Guys
https://www.daz3d.com/minimalist-maxi-dforce-maxi-dress-for-genesis-8-and-81-females
The usual boob question when simulating this dress it appears to have its own boob shape built in, i would rather dforce just let the dress drape over the figues boobs and not rely on a hidden shape that is larger than my figure in this case Mirage 8.1( i have tried dialing out mirages body to use the base 8.1 figure but it still does it.)
Thanks In Advance
  • crosswindcrosswind Posts: 10,343
    edited January 2024
    Yes, this dress seems designed for the char with big boobs... Anyway, you may try this way:
    - 1st, retrieve dForce Modifier Weight : Select the Dress, Create - New dForce Modifier Weight Node...(ss1)
    - Select the Weight Node, Alt + Shift + W. In Tool Settings, select Influence Weights, add more Sensitivity, Ctrl + Mouse Wheel to enlarge the cursor size. Then carefully paint the Weight in the related area to Red. (ss2)
    - Simulate. (ss3)
    2560 x 1400 - 917K
    2560 x 1400 - 779K
    2560 x 1400 - 778K
    Post edited by crosswind on
  • PitmaticPitmatic Posts: 1,025
    Thank you @crosswind for your invaluble help sorry to be slow to respond we have been having a lot of powercuts due to the storms and remedial works.
    No problem! Pls take your time, and take care!
