Show us more of your 3Delight renders
13435373940
  • fixmypcmikefixmypcmike Posts: 19,701
    Here's one from the RRRR challenge:
    Title: Who Doesn't Love A Beach Party?
    What could go wrong?  Everybody likes the beach.  Everybody likes food.  Alas, Jaime forgot that seagulls also like food on the beach.
    Love the ambience, cool!!
  • TynkereTynkere Posts: 834
    Thanks.  Will try not to interrupt too much or be too long.  Probably just something in render settings.  IN DS 4.12, it doesn't seem to like "Shadow Type Raytraced"   (On the render side, I just used 'default' with Progressive enabled and Gamma enabled at 2.2)  Took too long at 15 minutes, so cancel.  Didn't want to do hair & eyes.
    "3Delight message #45 (Severity 1): S2072: the shader 'C:/Program Files/DAZ 3D/DAZStudio4-V4_12/shaders/omnifreaker/displacement/omDispStandard2.sdl' uses a different interface version. Automatic conversion was successful. It should be recompiled for better performance."
    Deep Shadow Map (don't remember that one)  takes a while and gets the following error but at least renders.  AoA's "Metalized Glass Shaders" don't cast colored shadow as expected.  Settings for water in the glass could be better. For that matter the base board looks strange.  0_o
    Will look at the links on your sig.  : )z
    PS: Was it "Mustakettu" who had a script to convert mdl to rdl?  Script out there --> iray to 3DL?
    1080 x 810 - 900K
    There's this one:  https://www.daz3d.com/rssy-iray-to-3delight-converter-and-merchant-resource
     and a free one:  IrayTo3Delight conversion script - Daz 3D Forums
    but I haven't had much luck wiith either of them.
    edited January 2024
    Yup I have the free script, for some reason it puts the diffuse map into reflection color, which is of no use whatsoever + you can't use raytraced reflection with a colormap in there...and I don't recall it converting roughness values to glossiness either, so might aswell just apply whatever RSL shader you prefer;)
    Post edited by Sven Dullah on
    edited January 2024
    @Tynkere
    I'm using DS 4.20 and just today used a ds standard spotlight with raytraced shadows. What was trace depth set to in rendersettings? For raytracing to work you need min1 tracedepth, 2 should be more than enough, unless you really want reflective bounces between those glass surfaces to multiply.
    Regarding the AoA shaders...haven't used them for a looong time but they should work AFAIK, can do a test later...zzdevil
    Did you use any GI light? If you use no bouncelight and have no ambient light in the scene, the dark areas will take longer to calculate. You could try adding the UberEnvironment2 in ambient mode (no tracing) at a very low intensity, could help with rendertimes.
    Hair...complex hair and standard spotlights with a high shadowsamples value is a bad combination, really. Two thoughts: Use AoA spotlights with transmapped stuff flagged for alternative samples, and use OmUberSurface with occlusion disabled. Worst case scenario: Use two copies of the hair, one without opacitymaps but with "Fantom" enabled, so it does not show in render but still casts shadows. For the other copy, turn off shadows.
    Check the offending opacity maps in an image editor. If they are properly done there should be only black and white values. If not (probably not), fix them:)
    Oh, and while I'm at it...if you use a standard spot, set falloff to 2 for correct physical behaviour, and set light intensityscale to 1000000 or along those lines;) When you have enough light, use the regular intensity slider to fine tune!
    edited January 2024
    @Tynkere
    Applied the AoA crownglass teal to the sphere, created a ds standard spotlight with raytraced shadows, seems to work as expected in DS 4.20...
    ...and Carnival tealgold
    Trace depth 1 is enough to get the colored shadows, however, if you also make the groundplane reflective, you'll need atleast 2 for the reflections to show:image
    And no, forget deep shadow maps, they are not raytraced so the shadow will always just be black, and they render much slower for that matter;)
    800 x 494 - 193K
    800 x 494 - 229K
    800 x 494 - 242K
    edited January 2024
    Thanks both of you about scripts.
    Glad to know to avoid deep shadow and concentrate on why raytrace gums up.  Must have color glass shadows!  ; )
    For some reason -- maybe it's 4.21-- I thought Awe-surface and Uber had been 'simplified' -- no pulldown menu for textures.
    Thanks for tips on what I should look for & how to improve.  Will play with it in DS 4.20 tonight.
    @Everyone
    Everyone's renders very well done. I have a lot re-learn, then learn even more.
    Apologies if this was intrusive tho.  "Show us your renders" topic not supposed to be Q&A!
    Best wishes & thanks for your patience. : )
    Post edited by Tynkere on
    No worries mate, glad to help if I can!
    edited January 2024
    Converted the "Majestic" to awe, think it's ready to roll...
    2400 x 1350 - 3M
  • csaacsaa Posts: 944
    Sven Dullah,
    It looks good! Coupled with the pearly environment lighting, the car is a showroom eyecandy.
    Cheers!
    Thank you! I've been eye-balling it for quite some time, great model!
    Very nice indeed.  Incentive spurs effort.  Want to be able to do that!  Belated new year's resolution.  : )
  • FirstBastionFirstBastion Posts: 8,049
    Revisiting 3Delight rendering. Victoria 6 HD
    Lense flare a nice touch and (for me at least) shows what hair, teeth, eyes, & clothing should look like when someone knows what they are doing.  ; )
    Can't argueyes
  • nattaruknattaruk Posts: 547
    Title: Iolanthe in the Temple
    After looking at some of my first ever renders, made back  in 2015, I thought I would revisit and rework a few of them. I am not self-confident enough to show the original but this is much better!
    Beautiful!
    Very brave of you to go back to those days, I rarely want to look back at all the crap stuff I've been posting over the years...when I do, it always makes me feel uncomfortable haha.
    But it has been quite a journey so far, and hopefully it's far from over:-)
  • wsterdanwsterdan Posts: 3,077
    Totally gorgeous render. My interest is mainly stylized/toon rendering, but I understand people whose hobby is to try to make things ultra-photorealistic. That's their hobby. To me, though, this render is more than "real enough" (to quote the Doug and the Slugs song). While 3D fanatics might sit down and find things that don't look "real", I firmly believe that the vast majority of people won't find any faults. If this image was in a magazine they were flipping through, they wouldn't stop and comment that it's not real.
    Very well done!
    Beautiful!
     I think its important to look back on occassion,  to see the progression and the development of the craft.  My Day in a Life thread was started in 2012, so hitting 12 years,  some of that old stuff would have been affected by the tools in those days  as much as the ability to put them to use, and yet,  I was younger and more creative than I am now.  We all grow.  Key is, try to learn something new everyday.
    edited January 2024
    Very well done!
     Thank you. I'm in the good enough school of thought for creativity.  Sometimes you just want to be a photographer and place a couple spotlights and see what develops.  The most time was spent getting that hair under the hoodie.
    I will mentioned that this render is with DS4.10  I don't think I would try to render with 3DL with any of the versions after DS4.12
    Thisyesyessmiley
    Thanks for sharing your beautiful render and thoughts!
    May I ask the reason why?
  • JOdelJOdel Posts: 6,322
    edited January 2024
    Vyktoria also has a couple of Iray-->3DL converters over at Rendo.  I've had good results from them.
    Post edited by JOdel on
    Yes, I was curious too.  While most of my renders are done in DS4.8, this one was in the latest 4.22 beta:
    Tag: Fixmypcmike Pull #3
    Title: Goths In Space, the Motion Picture
    The Producer: "You idiot!  When Jack Tomalin called it 'Goths In Space' he meant it evoked a gothic architecture style.  He wasn't talking about actual Visigoths!  And put those knives away, you're making me nervous!"
    Pulls: 2544 336 3107 437
    Dagger Dreams 15813  https://www.daz3d.com/dagger-dreams
    Now-Crowd Billboards - Barbarian Warriors Fighting  81952  https://www.daz3d.com/now-crowd-billboards--barbarian-warriors-fighting-barbarian-warriors-vol-iii
    GIS Nova 10995  https://www.daz3d.com/gis-nova
    Misty River Gorge 47883  https://www.daz3d.com/misty-river-gorge
    Also used:
    Forlorn GIS Nova  18240  https://www.daz3d.com/forlorn-gis-nova
    GIS Nova Lights  12224  https://www.daz3d.com/gis-nova-lights
    DLD High Gloss Metallic Shaders  10137  https://www.daz3d.com/dld-high-gloss-metallic-shaders-for-ds
    The Producer (bald man):
    Genesis 1
    P3DA M4 Business Suit  8411  https://www.daz3d.com/michael-4-business-suit
    Mitch Hair  (a freebie from AprilYSH)  http://shop.aprilsvanity.com/free-items/mitch-hair.html
    Stolz  15498  http://docs.daz3d.com/doku.php/public/read_me/index/15498/start
    The Director:
    G2M
    Genesis Night Out Suit  15017  https://www.daz3d.com/night-out-suit
    Kung Fu Hair  19369  https://www.daz3d.com/kung-fu-hair-for-genesis-2-male-s
    i13 50 Essential Emotional Communication Poses 22975  https://www.daz3d.com/i13-50-essential-emotional-communication-poses
    Excellent stuff, @Fixmypcmikelaugh
    Thank you!
    Sorry for late reply.  Kind of got buried I guess.  They are on wishlist now.
    Thanks for the tip.  : )
    Fun stuff, thanks for sharing!
    Thanks very much also for including all of the assets used, much appreciated. You never know what's going to catch someone's eye in a render like this.
