• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Is it worth migrating assets from DAZ to Blender just for rendering?
tcassattcassat Posts: 77
January 2024 in Blender Discussion
I tested Blender for the first time and the render times I got with Cycles seemed much faster than iray, but I don't know if it's because of the assets I used.
The question is the title of the topic. If my intention is just to use exactly the same functions as I have in DAZ Studio, i.e. to pose characters in 3D environments obtained from the DAZ Store and render them, is there a significant advantage in doing this in Blender rather than DAZ Studio?
Thanks!
  • wolf359wolf359 Posts: 3,936
    January 2024
    For stills & portraits?
    No advantage
  • PadonePadone Posts: 4,024
    January 2024
    Blender has a simplify tool that is similar to the scene optimizer in daz studio. Cycles has a better denoiser and supports AMD and Intel cards, plus it provides motion blur. For animations eevee is much better than filament. Apart this, if you have a nvidia card and use the scene optimizer in daz studio, then there's no significant advantage to render still pictures.
  • hardwire666hardwire666 Posts: 74
    January 2024
    Blender will allow you to optimize your scene in ways Daz just can not do. This translates into faster render times. However as with any rendering program. If you don't now how to optimize it doesn't matter. I can render larger and more complex scenes faster in Cycles than I can in Iray/Daz.
  • nonesuch00nonesuch00 Posts: 18,763
    January 2024
    If you have to do lightweight one off modeling for the scene direct in Blender or have to do a lot of scene jiggering and test renders of your scene before you get to something you like then exporting to Blender is worth it. Also, if you want to use Eevee to create effects not possible in iRay, then it's worth it.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,255
    January 2024
    But do not discount the phenomenon where you thought you just wanted to render in Blender, but once you're actually in Blender you realize that now you've got your content in an extremely powerful environment, it liberates your creativity and you think of all sorts of things you want to do now that you didn't even think of before. Houdini is the same way.
  • ValiskaValiska Posts: 156
    January 2024
    That probably depends on what you're doing. It won't be for everybody. It's worth it to me. Once I took the time to learn Blender well enough to model, I also prefer to set up and render in it.
    1. Daz Studio moves around large landscapes so slowly it's painful. It becomes very time-consuming to set up scenes if you're using such. I use large landscapes often.
    2. I can easily increase the size of Blender interface text to the point where I can read without eyestrain on any monitor.
    3. Nevertheless I have more screenspace available for the scene, instead of the interface, since I had to learn keyboard shortcuts to model efficiently in Blender. I don't need sidepanels open most of the time, and I can open and close them with a keystroke.
    4. Daz used to have terrific previews for 3Delight renders, but that's been working less well for a long time, with the switch mainly to Iray. What's up with old card hair? I now frequently see old hair pieces that looked fine in textured preview in 2013, now half transparent/disappearing, in a fashion that would have me fixing flipped normals if I saw it in Blender. The hair still renders in Daz Studio, but it's harder to tell what it's going to look like. And I'm finding it hard to look at a shiny Genesis model (different from generation to generation) and guess what the Iray render will look like. I can now look at a quick Eevee preview and make better guesses about the intended Cycles render.
    So I've installed Diffeomorphic and I've been exporting my entire Daz library for use in Blender. For the old 3Delight items, I run RSSY's 3DL to Iray converter before export, so I'm starting out with PBR shaders for everything. I then can meddle with the materials further in Blender for individual scenes.
  • Hurdy3DHurdy3D Posts: 1,076
    January 2024
    Lighting is in Blender much better than in Daz.
  • DissendiorDissendior Posts: 129
    January 2024 edited January 2024
    I tend to do so more and more because - what mentioned earlier - I HATE navigating large scenes in DazStudio. It's really awful. And I am already much better in doing the adjustments in Blender, for example some clothing that is not lying correctly and dForce in Daz may not work - I can use Blender's scultping to do the necessary changes. Also I can use props and scenes from elsewhere (cgtrader, turbosquid etc.) more easily. I always felt like importing 3rd party objects into daz is much more complicated as you need to adjust all the shaders all the time, even with PBR materials. Another advantage is animation if you want to go that way. I am not very experienced but what I've seen so far animation in daz also is a pain where as Blender is much more handy for that.
    For getting scenes, characters and poses into Blender I use diffeomorphic. Most of the time it#s working very well
    Post edited by Dissendior on January 2024
  • csaacsaa Posts: 943
    TheMysteryIsThePoint,
    When switching from one toolset to another, it helps to be aware of the paradigms we carry over and, when necessary, to be nimble in adapting the old to the new. Coming from Daz, I took to Blender looking for the same features and workflows. To some degree this helped, as Daz and Blender share commonalities. But in other aspects sticking with the Daz way of doing things only hindered me.
    dForce is one example that tripped me up. I thought the solution to clothing peek-throughs in Blender was to simulate the scene -- figure, clothing pose and all -- to get the clothes settled well on the figure. Just as in Daz. This turned out to be more trouble than I had bargained for! In the end, I turned to Blender's sculpting tools. For generating still images, I've found this to be the easiest way around the problem.
    As to Houdini, I've dipped my toes into it from time to time. All these new concepts -- SOPs, VOPs, etc. -- with little in terms of paradigms carried over from Daz and Blender. My intiution tells me that the key lies in approaching Houdini as a programmer; that is, to view those network nodes in terms of data flow graphs that transform geometry and vectors, whatever the later represents.
    So many intersting things to learn ... so little waking hours to dabble in them. Alas, such is life. smiley
    Cheers!
    Post edited by csaa on January 2024
  • Singular3DSingular3D Posts: 615
    January 2024
    I use a lot of different software for creating images. Daz is mainly used for characters and assets of other software is combined in Blender for the final image. I also tend to improve Daz assets in Blender. For complex scenes, I have many more options in Blender than in Daz even for stills. There is a certain learning curve, but Blender is constantly improving and gets better. Diffeo is a grest tool to get the Daz content over. I really hoped that G9 would be useable in Blender as good as in Daz. At least Daz is a content provider.
    January 2024
    Cheers!
    Very well said, @csaa
  • DrGonzo62DrGonzo62 Posts: 382
    November 2024 edited November 2024
    In short: I don't think it's worth the hassle.
    I use DS exclusively to create scenes using existing assets and to then render stills and animations from them using nVidia cards.
    While Blender has a lot more features than DS, it's also a lot less focused than DS, and to me at least has way more features than I need.
    I use Motionbuilder instead of Maya for the same reason. When I do animation work, I simply don't need all that additional functionality that clutters the Maya interface.
    * I don't think Cycles renders any faster than Iray.
    * Positioning cameras and lights is way easier in DS than it is in Blender. I had to purchase an addon for Blender to easily lock the camera to the viewport for positioning without having to open extra panels. That is build into DS, and a default in most 3D applications as well.
    * Getting DS assets to work as well or at all in Blender will require a lot of fiddling. Converting shaders, character rigging, mesh deformations, dForce simulations etc. I guess that some of that could be done in Blender as well, but that isn't time well spend as far as I'm concerned.
    * EEVE renders much better than Filament, but that won't matter if you don't want to use openGL for renders.
    In closing; while there are way too many issues with DS for my liking, I can appreciate its scene creation and render workflow compared to Blender.
    I toyed with the idea of moving to Blender instead of DS, and ended up staying with DS for these reasons.
    Just my 2 cents, since I didn't see a similar sentiment posted here. Your mileage may vary.
    Post edited by DrGonzo62 on November 2024
  • mikael-aronssonmikael-aronsson Posts: 599
    Cycles render at about the same speed as iRAY with default settings, with a few tweaks Cycles render much faster with same quality.
    A big scene that does not fit in GPU memory can still be rendered with Cycles and performance is not bad at all, it's not like iRAY crawling around in the sand on the CPU.
    As [poor] as the Blender UI is you can actually set it up so it can be used on a high resolution monitor (one of my top 3 reasons to switch to Blender), the only thing you need is the "Simple tabs" plugin (free) that fix the N panel problems with a larger font, (as long as you can learn to live with middle mouse buttons, crazy collections behavior, vertical tabs with text, no delete button working and a camera setup that is beyond crazy and the outliner where you have to do everything two times of course).
    The asset manager in Blender makes it easy to navigate all your content, almost as easy as in DS.
    Physics in Blender is much better, dForce is a pain to setup so it get anything done the same day.
    Blender takes you away from sitting in nVidias lap to some extent also.
    And we have Thomas and Alessandro of course, without them nothing of this would be possible at all (you would have to use the DAZ to Blender bridge crying ).
    If you one day decide you want to animate anything you can actually do that in Blender.
    You can no longer buy mesh grabber so if you want to change anything with your content or have nasty poke through you need to get it out of DS anyway.
    Post edited by Richard Haseltine on November 2024
    @mikael-aronsson
    Thanks for your feedback.
    In a separate thread here, I asked if there is an equivalent to DS Iray Section Planes available for Blender, but that doesn't seem to be the case right now.
    I hardly ever render anything in DS without using multiple section planes. This is invaluable to cut down on render times, especially for longer animations.
    I came across a Blender addon called nView by Spencer Magnusson, which will hide outside of the camera view's scene geometry from the renderer, but this will also hide any mesh lighting hidden by this addon, and therefore most likely be changing the overall scene lighting.
    Without this crucial functionality, Blender is completely useless to me.
    I have several RTX 30xx cards in my render rigs, and I still need section planes that will keep the overall scene lighting intact for my renders, or my electricity bill would be even worse.
    While you've made some very valid points, the current absence of section plane functionality make Blender a non-starter for a "carefully set up a scene and then render the frames as fast as possible" creator like myself.
    This isn't meant as a criticism of Blender, but rather a heads-up for other DS users like myself who frequently render hundreds or even thousands of frames, and who have started to consider moving from DS to Blender.
    Have you actually tried ? "I don't think Cycles renders any faster than Iray" is not that productive.
    I do not understand the obsession with the section plane cutting node in iRAY, as long as you don't actually need to cut away part of an object (you can do that with booleans) you do the same with hiding objects from the camera in Cycles, but with Cycles you can also actually hide an object from the camera and still have it contibute to scene lighting and cast shadows (if you would like to), iRAY does not do that.
    I have rendered G8 characters in Blender and with 2 minutes of tweaking Cycles I got it to render about 5 times faster on Cycles without any quality loss, and as I said, Cycles work on almost any kind of hardware, no one would use iRAY CPU rendering for a big scene that does not fit in VRAM, that is doable with Cycles.
    But yes, there will always be some messing around to get DAZ stuff to work in Blender, it will never be a one button solution, if you are not prepared to live with that you should stay with DS/iRAY.
    Post edited by mikael-aronsson on November 2024
    mikael-aronsson said:
    I have rendered G8 characters in Blender and with 2 minutes of tweaking Cycles I got it to render about 5 times faster on Cycles without any quality loss...
    This there an article or tutorial on how to achieve this feat?
    Nevermind.
    OK, so I spent some time in Blender and I have to admit, that I'm increasingly getting into it.
    I got caught off guard today when I switched from cycles to EEVE, and that G8 sitting on the floor looked like an Iray
    render at first glance. The animation played back almost in realtime, but not in DS openGL or filament, but almost in Iray
    quality.
    Now that - is very nice!
    Might really be worth it making that switch.
    November 2024
    Be aware that eevee is a screen space renderer, that means objects outside the camera will not contribute to lights and reflections. This requires some planning when doing animations with eevee, but yes, the overall quality is quite good. On a side note eevee automatically clips objects outside the camera so there's no need for section planes.
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,651
    November 2024
    "poor" ? You are joking, right?
  • Richard HaseltineRichard Haseltine Posts: 108,459
    November 2024
    UIs are a matter of taste. De gustibus non disputandum est.
    If "poor" is intended as lacking of features or minimal (in terms of features), that is axiomatically wrong. I defy anybody saying that Blender has a UI that doesn't offer all the controls that are needed to use the software properly, or customizations to adjust it at your needs. If it's intended as "ugly" or "depressing" or something like that, then it might be a matter of taste. In that case, out of curiosity, I wonder what definition one could find for the Studio's UI...
    Post edited by Alessandro Mastronardi on November 2024
  • WolfwoodWolfwood Posts: 876
    November 2024
    I might be remembering wrong. But i think the OP used 'colorful' language and mod changed that only bit to avoid deleting the entire post. I think "poor" does not reflect the original opinion.
    November 2024
    That's a pet peeve of mine, as well. Whether a UI is efficient or not can be evaluated objectively. Whether any particular user is going to like it, cannot. Two examples from programming: 1) You may not like Vi, but no one can deny that it is well designed and powerful. You may prefer spaces over tabs, but you can't deny that tabs are in the dog-gone ASCII table specifically for formatting, just like on a typewriter.
    The urge to describe objective things that one doesn't like as being subjective is quite strong.
    But to the OP, I agree with some others who said that if you are moving to Blender just to render, you are cheating yourself out of a lot of amazing possibilities after you've done the hard part... you're in Blender... why not look around and see whate's there? :)
  • savagestugsavagestug Posts: 200
    November 2024
    DS UI isn't bad, but there are for sure a lot of quirks and omissions that are really frustrating for people with experience with other DC platforms. Blender UI isn't bad, just frustrating for those who have used other DC platforms.
    After this Premiere thing, I have been much more seriously looking at Blender. Blender is deep, and there will be a learning curve before becoming efficient with the software. But, OMG...the amount of Blender add-ons out there is crazy,
    November 2024
    It really all depends on what you know. If Daz is all you know then you will be able to do things 1000000000x's faster in Daz and Blender will just slow you down. Where as for me. I know Blender very well so Daz slows me down. I can create a multi-hudred million poly scene using Blender in the same amount of time that it would take me to create a pose I am happy with in Daz. Which is an exaderation but you get myu point. So for me it's worth it.
    What is worth it no matter which way you split it is learning to use Blender.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
