Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
i'll do the needed fixes this Saturday/Sunday
in the meantime look at this cute bass guitar which is so very close to being released as a freebie
Hi Casual
It looks terrific
Great job
re Beta testing
Hi Casual
Here are the two Screen shots,
If you look at the without shot, you can see the notes on and off on the MIDI time line HIAT note 44
whereas in the with shot you can see the note on's have gone on the MIDI time line HIAT note 44
Kind wishes
Keiron
i think i'll add a panel where you can view the channels as a table or text
say, 1st colimn the time in frames, column 2 the time in seconds, and ms 3rd the type of event
also if you could point me to the midi file you are using i could use it in my tests
there's all sorts of possibilities, for what can go wrong and sometimes the problems only show when using specific files
for instance, some midi files may say "Note ON" others may say "note on"
Hi Casual
Pop me an Email and I'll send you the MIDI file and the Excel file
keironatkeiron.me.uk
put the @ sign in
Sorry I can't add or send some attachments on the Daz site it said not allowed?
Hi Everyonel
Boogie Slide Played and Animated by me
Big Thank you to Casual for the MIDI load script
Added some Trombones and Camera Angles
Still working on the Sax and Drums LOL
Great fun
https://youtu.be/1CV_0TI5hzM
now that the mcjSphereCam script is complete
i return to the midiLoader script !
here's the Inspector panel of the upcoming version
and if what's displayed is correct
there's definitely a problem with the hi-hat hits
the Quantize option was probably used when loading that midi file
and the hi-hat Note-Off events are so close to the NoteOn events that they over-wrote most of them
i think for now, one could load the midi file with Quantization Off
then set Quantization On when applying them to the animated instruments
Hi Casual
Well done with Inspector panel, very useful, that's exactly what i'm seeing with Keymate.
I did import the midi text with Quantization Off and all the note on and off were there OK, but the note on and off were way to close.
I then moved the note off's manually along 2-3 frames before the next note on and got a much better animation.
Also as explained in the Email the drum data forms a pattern which you may be able to Analyse and use to improve the animation as a simple note on and off sets the animation to zero each time
Kindest wishes
Keiron
At last ! some new developments on the midiLoad front
when Quantize is ON
there's a math function named "floor" and a math function named "ceiling"
they are similar to the "round" function
say you have a midiON event happening at frame 100.135
and a midiOFF event happening at frame 100.235
if we apply the floor() function, the noteON event will happen at frame 100
and if we apply the ceiling() function the noteOFF event will happen at frame 101
before today, both the NoteON and NoteOFF events were using the round() function and would be mapped to frame 100
i just have to check if the Inspector panel works well
then i'll post this new version !
in the image below you can see the before and after
note that this solves most problems with HiHat type of MidiNotes which had the NoteOFF event extremely close to the NoteOn event
but if the drummer is drumming faster than 30 beats per second ( or 15?) then there will be missing moves
also, even after this change the drum movements remain very short
but at least they are present in the midi-node's timeline
the task of animating the drummer's arm with a longer duration will be achieved through new "effect" ... or something :)
the first 10 seconds of "yoursong.mid"
the closed-hi-hat applied to a D-Form of the new McjBookShelfSpeaker prop
not missing a beat !
i rendered this at 30 fps
then in virtualDub, i applied a "motion blur" effect"
so i was able to reduce the frame-rate of the animation to 10 fps
and we still can perceive every beat
for pro results, one could render/animate at 90 fps, add motion blur and reduce the final frame rate to 30fps
NEW VERSION ( still beta but hey )
July 5th 2015 - new version with Inspector panel and better handling of extremely brief midi ebvents like those on drums
download MCJMIDILOADSUPERSECRETBETAJULY05.DSA and MCJMIDILOADSUPERSECRETBETAJULY05.DSA.png
and place them in your scripts/mcasual folder
Hi Casual
Thank you for the new link and update I'll give it a try
Kindest wishes
Keiron
Hi Casual
Sorry for the delay
I had to rebuild my machine due to a faulty SATA cable connection on a Drive
Everything is now back and I have reinstalled all the software
Well I loaded a drum and the script and ran the script but i've hit a prob that we have seen before
"fatal error could not load file"
I pointed the script to the existing Mf2t.exe file, no joy
moved it to the c drive,
moved it to the "my daz 3d library"
no luck
I then went to downloaded the MIDI to text file but it's moved location, so I downloaded it from its new location. I unzipped it but there is no exe it might be compressed?
The only difference is my content in on a second drive at this time, the "my daz 3d folder" on the c drive user documents is currently empty except for the newly added mf2t folder.
Solved it
The Folder was not using full Admin
so I right clicked on the folder selected security in users (keiron\users) what ever yours is
"logged on as admin" using edit I gave this folder full permission and all is well now works OK
Hi Casual
Seeing some problems
I'm using july 05 is that the right version?
I've loaded the same midi file as before it's converting fast but on loading the text file it's now taking 6 mins instead of 1 min 25 sec
its at 100% in 38 seconds
That's using a 4Gig quad I7 rev 4 the cores aren't flat out
I have used Quantize on and off both give the same result at 30 fps
The good news is they are right on the mark of every frame and not sitting between
The bad news is the note on's are still being destroyed
I've just set it to 60 fps ill let you know what happens
Beta update june05 script
Still trying to find out why Daz Studio and script is slower, I must need to install something else for the MSI motherboard, just installed the MSI Command program and enabled the Genie but that didn't seem make a lot of difference. I'll keep you posted, I'm confident it's not the script taking longer but some other issue.
OK so I've looked at the time line in Keymate using the latest script and the previous one
I can see the MIDI timeline has note on's and off's in the previous version where as not the case in the june 05 version it has notes missing
This is reflected in each case in the hiat timeline
There is however a great improvement as the notes are now hitting the time line exactly on each frame with the new version
I also tried with 60 fps but got the same result
since mcjMidiLoader is a script and not a plugin, it's quite slow when dealing with large amounts of data
for example .... loading all the midi events from channel 0 into the Inspector panel's "ListView"
in future versions i'll probably disable the inspector by default
in the meantime, if you want to disable the inspector feature
open MCJMIDILOADSUPERSECRETBETAJULY05.DSA
in the Daz Studio scripting IDE or in NotePad/Wordpad
scroll down to line 582
which looks like this
function UpdateInspector() {function UpdateInspector(){ return;Hi
I have now tried the same script in Daz Studio 4.8 32 bit and 64 bit
It took just over 50 seconds to complete using the 32 bit version and over 6 min to do the same with the 64 bit version
So the 64 bit version is considerably slower
I've run the Intel Processor and Motherboard checker and all is well the perormance test is around 4600, so it's not to bad
re Beta version
I can still see notes missing at this time, even with the 32 bit version
Looking forward to your next beta version
Thank you for your hard work
Kindest wishes
Keiron
Hi Casual
Just dropped by to see how your are getting along
i didnt modify the midi project
but i did all sorts of things
but this weekend it's mostly , for fun, building/rendering scenes
of course i wrote and used custom scripts to do that !, like changing the bottom curve of a dress for instance
Hi Casual
Great Render, looks brill
Well I thought i'd go for the Windows 10 upgrade
For the most part it worked well and installed OK
I had issues with the Video NVIDIA driver but i've got an updated version for Windows 10, so now OK
I was using Antivirus / Internet Bit Defender but after the Windows 10 upgrade Bit Defender stopped me from visiting sites, so it's been removed and AVG installed, all is now OK
On the face of it it look's a lot better the Start menu is back but the Control Panel is missing, but you can search for it
Still running through all the programs to check there operations
The time delay I get using Daz Studio 32 bit and 64 bit using the same script is still there so not luck on that one
Perhaps you could try the same test to see if you get the same result as me
Have a great weekend and happy renderings
kind wishes
Keiron
If you would accept a disinteressed opinion... Don't use AVG!
It will invade your PC with useless plugins and Browser Helpers... And it doesn't recognize viruses!
Use Avast instead!
Hi Imago
Yes thank you for the advise, i'll give it a bash
No big problems with Daz Studio 4.8 using windows 10 so far
Happy rendering
Hi Casual
Well thats a suprise!!!
I rebuilt my old i7 and used windows 7 64 bit
I've installed Daz Studio 64 bit
Placed the original mf2t folder in the programs x86 folder and set user permissions to everything
ran the script
Converted same MIDI file, and loaded txt file and yup loaded around 1 min 14 sec np about the same as the 32 bit version
So it's a problem with my other MSI gaming 7 motherboard with the new i7 proccessor or Windows 8 >
or some process?
it's hard to tell, the disk access by mcjMidiLoader is not a big task
if other things not related to midiloader are running slow in Daz Studio , then it's something in your installation that slows things down
long ago in DS3 i remember there was a plugin that was causing problems, so i went in the DS4 /plugin/ folder and moved some dlls out of Daz reach, thereby removing them from Daz Studio at load time
another thing you could try is close some panels, like the Animation Plugin panels
because a great number of keyframes are added to the midi node and if there's a plugin that reacts to each keyframe being added ( to display the animation curve for example ) this may slow things down
Hi Casual
Now thats a thought
I have only installed daz studio 4.8 64 bit pro in the old pc theres no plugins or anything else installed as yet
and there's not alot installed in the 32 bit version either as i don't use it that often
i'll give that a go
Thank you
Hi Casual
Script is now taking 43 seconds
Well this is really odd
Reinstalled Daz Studio 4.8 from scratch using the download tool to uninstall and reinstall
I didn't delete any folders or registry settings
It loaded all the tabs I had added or moved around before
I closed down each tab I had open, until I was left with the scene, content, enviroment and script and reopened Daz Studio
run the script now 42 seconds not 6 + mins "yey cool"
I then tried to re add the tabs back in and I couldn't get them to attach to the bottom or left hand side of the window?, so I started adding them to the top and righthand side
Each time I added a tab I closed down Daz Studio and restarted it, rerun the script and some of the tabs started to effect the script time but only by a few seconds
I then had all the same tabs open and the time is still only 47 seconds
So all I have really done is closed the tabs and added them to the top and righthand side
Mega difference to the script time now, loading MIDI text file down from 6 min + to 43 seconds
It was taking well over 6 min to open the Inspect panel , and each time I changed channel also 6 min +
Now less than a second working fine
If I reload the layout or change it to a different one, I think it will then allow me to attach the tabs to left and bottom again but i'll keep it as is for now
Thank's for the idea's
I can now assist you with some BETA testing when you wish
Kindest wishes
Keiron
Rendered in daz Studio 4.8 using open GL
Rendered in Daz Studio 4.8 using 3d delight
Hi Casual and Everyone Welcome
This is a short Animation by me. A big thankyou to Casual who wrote the Daz Script to allow animation of objects using MIDI files.
After I created the song, I then made a MIDi file type 1 and a Wave file. Using Daz Studio I have then Synced every note played to the Models hand movement so it's taken nearly 60 hrs to complete
There is a second piano and other Intruments that I haven't as yet included as yet but hope to in the near future.
Thank you for watching
Kindest wishes Keiron
Hi Everyone
Drum track revised using "MIDIHelper" a program I'm writing in Excel using VB, Animation created Using Daz Studio 4.8
Music created by Keiron Westguard
Big Thank you to Casual for his MIDload script to animate Objects using MIDI
Drum Video below if you would like to take a look Instrument only at this time
The actual MIDI file was causing some problems that needed to be delt with before using MIDIload
I've have Identified these as follows
1. A MIDI note On could be in the same time stamp as as another Note On both have the same note
2. A MIDI note Off could be in the same time stamp as as another Note Off both have the same note
3. A MIDI note On - Off could be in the same time stamp as as another Note On - Off both have the same note
4. It's also possible to have multiple occurrences of the same note in the same time frame
5.The time period between a Note On and it's Note are very close together in the MIDI file making Animation very difficult
So after reading the Excel Spread sheet using VB for Dummies bought from Amazon LOL. I started on my quest to make an Excel sheet to help me solve all the problems using it's in built VB
Why Excel, well I had Office 2010 and I wanted to make something that could show me where the issues were as well as fix them
I've called It MIDIhelper but it uses a lot of resources and isn't bullet proof yet but it does the job quite well.
First of all It's an Excel 2010 64 bit version running on Windows 10 64 bit Using an I7 quad with 16 gig of Memory although windows looks like it was taking 4 gig of it
Following using MF2T or a new one I found the other day midicsv-1.1, I've put these in the c:\programs folder IE the 64 bit side as I'm using the Daz 64 bit version.
You can then Open the Excel file MIDIhelper and do the following
load the MIDI text file
Select the option you wish using the tick boxes or leave as is
Press a button and let it complete
If all options are left ticked it will do the following
Find every note that has Velocity =0 and make sure the Note is set to OFF
Find every note that is set to OFF and set its Velocity to 0
Check that the Note On is more than 0 :- on a different Note LOL the note ON can be as low as 1
Having done this for every MIDI channel, each set of Info is resorted
If the Velocity to 127 is selected then all Note ON's will be set to full velocity, you can also do this in Casuals Script if you wish
At this point the Minimum value between the Note ON to it's next Note ON has been calculated
So if you now set the sliders for each of the Drum Instruments lower than the MIn you should be good to go
Press the next button, after a while all the Drum Note Off's are moved to your new locations
At this point you can copy and paste the MIDI data into a good text editor I found Text Pad works great use search to find \t and replace " " note 1 space to replace then save this and Import all into MIDIload
if you wish you can scroll down to Ch10 and look at all the settings
Note on event time, Modified Note off event time, Time Difference, Selection Code, Old Note Off time stamp, Note Off difference
I can Email you a copy of the Excel Sheet if you wish to have a play. please note its work in progress at this time
Here are some screen shots Of MIDi helper
here are the results after moving the Notes oFf on Ch10 and the Info for the other Channels
