First mcjMidiLoad Beta Available - Midi File loader script for Daz Studio
1…45679
  • mCasualmCasual Posts: 4,607
    edited June 2015
    i'll do the needed fixes this Saturday/Sunday
    in the meantime look at this cute bass guitar which is so very close to being released as a freebie
    1920 x 1080 - 1M
    1920 x 1080 - 479K
    1920 x 1080 - 327K
    Post edited by mCasual on
  • KeironKeiron Posts: 419
    Hi Casual
    It looks terrific
    Great job
    edited June 2015
    re Beta testing
    Hi Casual
    Here are the two Screen shots,
    If you look at the without shot, you can see the notes on and off on the MIDI time line HIAT note 44
    whereas in the with shot you can see the note on's have gone on the MIDI time line HIAT note 44
    Kind wishes
    Keiron
    1911 x 1080 - 323K
    1905 x 1080 - 292K
    Post edited by Keiron on
    keiron said:
    re Beta testing
    Hi Casual
    Kind wishes
    Keiron
    i think i'll add a panel where you can view the channels as a table or text
    say, 1st colimn the time in frames, column 2 the time in seconds, and ms 3rd the type of event
    also if you could point me to the midi file you are using i could use it in my tests
    there's all sorts of possibilities, for what can go wrong and sometimes the problems only show when using specific files
    for instance, some midi files may say "Note ON" others may say "note on"
    edited June 2015
    Hi Casual
    Pop me an Email and I'll send you the MIDI file and the Excel file
    keironatkeiron.me.uk
    put the @ sign in
    Sorry I can't add or send some attachments on the Daz site it said not allowed?
    edited June 2015
    Hi Everyonel
    Boogie Slide Played and Animated by me
    Big Thank you to Casual for the MIDI load script
    Added some Trombones and Camera Angles
    Still working on the Sax and Drums LOL
    Great fun
    https://youtu.be/1CV_0TI5hzM
    edited July 2015
    now that the mcjSphereCam script is complete
    i return to the midiLoader script !
    here's the Inspector panel of the upcoming version
    and if what's displayed is correct
    there's definitely a problem with the hi-hat hits
    the Quantize option was probably used when loading that midi file
    and the hi-hat Note-Off events are so close to the NoteOn events that they over-wrote most of them
    i think for now, one could load the midi file with Quantization Off
    then set Quantization On when applying them to the animated instruments
    777 x 497 - 51K
    Hi Casual
    Well done with Inspector panel, very useful, that's exactly what i'm seeing with Keymate.
    I did import the midi text with Quantization Off and all the note on and off were there OK, but the note on and off were way to close.
    I then moved the note off's manually along 2-3 frames before the next note on and got a much better animation.
    Also as explained in the Email the drum data forms a pattern which you may be able to Analyse and use to improve the animation as a simple note on and off sets the animation to zero each time
    Kindest wishes
    Keiron
    edited July 2015
    keiron said:
    Keiron
    At last ! some new developments on the midiLoad front
    when Quantize is ON
    there's a math function named "floor" and a math function named "ceiling"
    they are similar to the "round" function
    say you have a midiON event happening at frame 100.135
    and a midiOFF event happening at frame 100.235
    if we apply the floor() function, the noteON event will happen at frame 100
    and if we apply the ceiling() function the noteOFF event will happen at frame 101
    before today, both the NoteON and NoteOFF events were using the round() function and would be mapped to frame 100
    i just have to check if the Inspector panel works well
    then i'll post this new version !
    in the image below you can see the before and after
    note that this solves most problems with HiHat type of MidiNotes which had the NoteOFF event extremely close to the NoteOn event
    but if the drummer is drumming faster than 30 beats per second ( or 15?) then there will be missing moves
    also, even after this change the drum movements remain very short
    but at least they are present in the midi-node's timeline
    the task of animating the drummer's arm with a longer duration will be achieved through new "effect" ... or something :)
    1920 x 1080 - 269K
    the first 10 seconds of "yoursong.mid"
    the closed-hi-hat applied to a D-Form of the new McjBookShelfSpeaker prop
    not missing a beat !
    i rendered this at 30 fps
    then in virtualDub, i applied a "motion blur" effect"
    so i was able to reduce the frame-rate of the animation to 10 fps
    and we still can perceive every beat
    for pro results, one could render/animate at 90 fps, add motion blur and reduce the final frame rate to 30fps
    480 x 270 - 1M
    NEW VERSION ( still beta but hey )
    July 5th 2015 - new version with Inspector panel and better handling of extremely brief midi ebvents like those on drums
    download MCJMIDILOADSUPERSECRETBETAJULY05.DSA and MCJMIDILOADSUPERSECRETBETAJULY05.DSA.png
    and place them in your scripts/mcasual folder
    182 x 182 - 13K
    Hi Casual
    Thank you for the new link and update I'll give it a try
    Kindest wishes
    Keiron
    Hi Casual
    Sorry for the delay
    I had to rebuild my machine due to a faulty SATA cable connection on a Drive
    Everything is now back and I have reinstalled all the software
    Well I loaded a drum and the script and ran the script but i've hit a prob that we have seen before
    "fatal error could not load file"
    I pointed the script to the existing Mf2t.exe file, no joy
    moved it to the c drive,
    moved it to the "my daz 3d library"
    no luck
    I then went to downloaded the MIDI to text file but it's moved location, so I downloaded it from its new location. I unzipped it but there is no exe it might be compressed?
    The only difference is my content in on a second drive at this time, the "my daz 3d folder" on the c drive user documents is currently empty except for the newly added mf2t folder.
    Solved it
    The Folder was not using full Admin
    so I right clicked on the folder selected security  in users (keiron\users) what ever yours is
    "logged on as admin" using edit I gave this folder full permission and all is well now works OK
    edited July 2015
    Hi Casual
    Seeing some problems
    I'm using july 05 is that the right version?
    I've loaded the same midi file as before it's converting fast but on loading the text file it's now taking 6 mins instead of 1 min 25 sec
    its at 100% in 38 seconds
    That's using a 4Gig quad I7 rev 4 the cores aren't flat out
    I have used Quantize on and off both give the same result at 30 fps
    The good news is they are right on the mark of every frame and not sitting between
    The bad news is the note on's are still being destroyed
    I've just set it to 60 fps ill let you know what happens
    Beta update june05 script
    Still trying to find out why Daz Studio and script is slower, I must need to install something else for the MSI motherboard, just installed the MSI Command program and enabled the Genie but that didn't seem make a lot of difference. I'll keep you posted, I'm confident it's not the script taking longer but some other issue.
    OK so I've looked at the time line in Keymate using the latest script and the previous one
    I can see the MIDI timeline has note on's and off's in the previous version where as not the case in the june 05 version it has notes missing
    This is reflected in each case in the hiat timeline
    There is however a great improvement as the notes are now hitting the time line exactly on each frame with the new version
    I also tried with 60 fps but got the same result
    edited July 2015
    since mcjMidiLoader is a script and not a plugin, it's quite slow when dealing with large amounts of data
    for example .... loading all the midi events from channel 0 into the Inspector panel's "ListView"
    in future versions i'll probably disable the inspector by default
    in the meantime, if you want to disable the inspector feature
    open MCJMIDILOADSUPERSECRETBETAJULY05.DSA
    in the Daz Studio scripting IDE or in NotePad/Wordpad
    scroll down to line 582
    which looks like this
    function UpdateInspector()
    and change it to
    return;
    Hi
    I have now tried the same script in Daz Studio 4.8 32 bit and 64 bit
    It took just over 50 seconds to complete using the 32 bit version and over 6 min to do the same with the 64 bit version
    So the 64 bit version is considerably slower
    I've run the Intel Processor and Motherboard checker and all is well the perormance test is around 4600, so it's not to bad
    re Beta version
    I can still see notes missing at this time, even with the 32 bit version
    Looking forward to your next beta version
    Thank you for your hard work
    Kindest wishes
     Keiron
    Hi Casual
    Just dropped by to see how your are getting along
    edited July 2015
    Keiron said:
    Hi Casual
    i didnt modify the midi project
    but i did all sorts of things
    but this weekend it's mostly , for fun, building/rendering scenes
    of course i wrote and used custom scripts to do that !, like changing the bottom curve of a dress for instance
    Hi Casual
    Great Render, looks brill
    Well I thought i'd go for the Windows 10 upgrade
    For the most part it worked well and installed OK
    I had issues with the Video NVIDIA driver but i've got an updated version for Windows 10, so now OK
    I was using Antivirus / Internet Bit Defender but after the Windows 10 upgrade Bit Defender stopped me from visiting sites, so it's been removed and AVG installed, all is now OK
    On the face of it it look's a lot better the Start menu is back but the Control Panel is missing, but you can search for it
    Still running through all the programs to check there operations
    The time delay I get using Daz Studio 32 bit and 64 bit using the same script is still there so not luck on that one
    Perhaps you could try the same test to see if you get the same result as me
    Have a great weekend and happy renderings
    kind wishes
    Keiron
  • ImagoImago Posts: 5,792
    Keiron said:
    Hi Casual
    kind wishes
    Keiron
    If you would accept a disinteressed opinion... Don't use AVG!
    It will invade your PC with useless plugins and Browser Helpers... And it doesn't recognize viruses!
    Use Avast instead!
    Hi Imago
    Yes thank you for the advise, i'll give it a bash
    No big problems with Daz Studio 4.8 using windows 10 so far
    Happy rendering
    Hi Casual
    Well thats a suprise!!!
    I rebuilt my old i7 and used windows 7 64 bit
    I've installed Daz Studio 64 bit
    Placed the original mf2t folder in the programs x86 folder and set user permissions to everything
    ran the script
    Converted same MIDI file, and loaded txt file and yup loaded around 1 min 14 sec np about the same as the 32 bit version
    So it's a problem  with my other MSI gaming 7 motherboard with the new i7 proccessor or Windows 8 >
    or some process?
    edited August 2015
    Keiron said:
    Hi Casual
    ran the script
    or some process?
    it's hard to tell, the disk access by mcjMidiLoader is not a big task
    if other things not related to midiloader are running slow in Daz Studio , then it's something in your installation that slows things down
    long ago in DS3 i remember there was a plugin that was causing problems, so i went in the DS4 /plugin/ folder and moved some dlls out of Daz reach, thereby removing them from Daz Studio at load time
    another thing you could try is close some panels, like the Animation Plugin panels
    because a great number of keyframes are added to the midi node and if there's a plugin that reacts to each keyframe being added ( to display the animation curve for example ) this may slow things down
    Hi Casual
    Now thats a thought
    I have only installed daz studio 4.8 64 bit pro in the old pc theres no plugins or anything else installed as yet
    and there's not alot installed in the 32 bit version either as i don't use it that often
    i'll give that a go
    Thank you
    edited August 2015
    Hi Casual
    Script is now taking 43 seconds
    Well this is really odd
    Reinstalled Daz Studio 4.8 from scratch using the download tool to uninstall and reinstall
    I didn't delete any folders or registry settings
    It loaded all the tabs I had added or moved around before
    I closed down each tab I had open, until  I was left with the scene, content, enviroment and script and reopened Daz Studio
    run the script now 42 seconds not 6 + mins "yey cool"
    I then tried to re add the tabs back in and I couldn't get them to attach to the bottom or left hand side of the window?, so I started adding them to the top and righthand side
    Each time I added a tab I closed down Daz Studio and restarted it, rerun the script and some of the tabs started to effect the script time but only by a few seconds
    I then had all the same tabs open and the time is still only 47 seconds
    So all I have really done is closed the tabs and added them to the top and righthand side
    Mega difference to the script time now, loading MIDI text file down from 6 min +  to 43 seconds
    It was taking well over 6 min to open the Inspect panel , and each time I changed channel also 6 min +
    Now less than a second working fine
    If I reload the layout or change it to a different one, I think it will then allow me to attach the tabs to left and bottom again but i'll keep it as is for now
    Thank's for the idea's
    I can now assist you with some BETA testing when you wish
    Kindest wishes
    Keiron
    edited November 2015
    Rendered in daz Studio 4.8 using open GL
    Rendered in Daz Studio 4.8 using 3d delight
    Hi Casual and Everyone Welcome
    This is a short Animation by me. A big thankyou to Casual who wrote the Daz Script to allow animation of objects using MIDI files.
    After I created the song, I then made a MIDi file type 1 and a Wave file. Using Daz Studio I have then Synced every note played to the Models hand movement so it's taken nearly 60 hrs to complete
    There is a second piano and other Intruments that I haven't as yet included as yet but hope to in the near future.
    Thank you for watching
    Kindest wishes Keiron
    1920 x 1080 - 857K
    Hi Everyone
    Drum track revised using "MIDIHelper" a program I'm writing in Excel using VB, Animation created Using Daz Studio 4.8
    Music created by Keiron Westguard
    Big Thank you to Casual for his MIDload script to animate Objects using MIDI
    Drum Video below if you would like to take a look Instrument only at this time
    The actual MIDI file was causing some problems that needed to be delt with before using MIDIload
    I've have Identified these as follows
    1. A MIDI note On could be in the same time stamp as as another Note On both have the same note
    2. A MIDI note Off could be in the same time stamp as as another Note Off both have the same note
    3. A MIDI note On - Off could be in the same time stamp as as another Note On - Off both have the same note
    4. It's also possible to have multiple occurrences of the same note in the same time frame
    5.The time period  between a Note On and it's Note are very close together in the MIDI file making Animation very difficult
    So after reading the Excel Spread sheet using VB for Dummies bought from Amazon LOL. I started on my quest to make an Excel sheet to help me solve all the problems using it's in built VB
    Why Excel, well I had Office 2010 and I wanted to make something that could show me where the issues were as well as fix them
    I've called It MIDIhelper but it uses a lot of resources and isn't bullet proof yet but it does the job quite well.
    First of all It's an Excel 2010 64 bit version running on Windows 10 64 bit Using an I7 quad with 16 gig of Memory although windows looks like it was taking 4 gig of it
    Following using MF2T or a new one I found the other day midicsv-1.1, I've put these in the c:\programs folder IE the 64 bit side as I'm using the Daz 64 bit version.
    You can then Open the Excel file MIDIhelper and do the following
    load the MIDI text file
    Select the option you wish using the tick boxes or leave as is
    Press a button and let it complete
    If all options are left ticked it will do the following
    Find every note that has Velocity =0 and make sure the Note is set to OFF
    Find every note that is set to OFF and set its Velocity to 0
    Check that the Note On is more than 0 :- on a different Note LOL the note ON can be as low as 1
    Having done this for every MIDI channel, each set of Info is resorted
    If the Velocity to 127 is selected then all Note ON's will be set to full velocity, you can also do this in Casuals Script if you wish
    At this point the Minimum value between the Note ON to it's next Note ON has been calculated
    So if you now set the sliders for each of the Drum Instruments lower than the MIn you should be good to go
    Press the next button, after a while all the Drum Note Off's are moved to your new locations
    At this point you can copy and paste the MIDI data into a good text editor I found Text Pad works great use search to find \t and replace " " note 1 space to replace then save this and Import all into MIDIload
    if you wish you can scroll down to Ch10 and look at all the settings
    Note on event time, Modified Note off event time, Time Difference, Selection Code, Old Note Off time stamp, Note Off difference
    I can Email you a copy of the Excel Sheet if you wish to have a play. please note its work in progress at this time
    Here are some screen shots Of MIDi helper
    1910 x 1047 - 273K
    1910 x 1074 - 378K
    1913 x 1048 - 307K
    1922 x 1057 - 256K
    1907 x 1057 - 266K
    here are the results after moving the Notes oFf on Ch10 and the Info for the other Channels
    1913 x 1076 - 399K
    1910 x 1047 - 372K
