Suddenly simulation becomes very slow
JamesJames Posts: 1,191
edited January 2024 in Daz Studio Discussion
It usually not this slow
even the
Simulating...
Initializing Simulation..
took 3 mins
not including the simulation which only 15 frames
took 10 mins
I know this is not normal, cos I simulate often in the same scene.
rtx 4070ti 12gb
what could be wrong?
Post edited by James on
  • felisfelis Posts: 6,632
    One or more very dense meshes?
    Do you get many springs that violate collision distance?
    What are you trying to simulate?
  • crosswindcrosswind Posts: 10,356
    edited January 2024
    Under some circumstances,  e.g. when there're quite a few dForce items with Enable Smoothing - On, improper settings on dynamic surfaces, or more collisions on poly, edge and vertex (Collision Mode - Best), simulating with Timline with more Inititialization Time will take much longer in terms of total simulation time. Pls check...
    If it is the same scene, same dForce items and same settings, it took 3 mins to simulate yesterday but 13 mins today... THAT is an odd thing....
    Post edited by crosswind on
  • My suspicion would be that it is, as I think felis was suggesting, a lot of edges thata re shorter than the Dynamic Offset value - listing those can take a while (and DS doesn't process thee vent queue while it is doing so) and then the fight between the rest-length of the edges (which act as springs during simulation) and the minimum offset keeps pumping energy into the simlation making it 9at best) slow to settle. If you have the progress bar expanded you should see the messages relating to this, and they will also be in the log file (Help>Troubleshooting>View Log file). If that is the issue then, depending on the degree to which the edges are too short, you may be able to improve matters by lowering the dynamic offset value in the Surfaces pane (but you may then need to adjust the collision detection settings to avoid poke-through, with its own speed penalty).
  • JamesJames Posts: 1,191
    I found out the problem.
    Somehow I keyframe a wall accidetanly, It gets moved.
    Although not sure why the wall makes everything slow.
    But I took out the keyframe and all back to normal.
    Thank you all.
