Let's appreciate/discuss today's new releases - ongoing thread
1…6061636566…100
  • I also wasn't sure about the way this as marketed, as being able to combine characters with different features and not have the products artificially separated out by gender was one of the selling points of G9, so why make a "male" product tied into requiring Victoria rather than just a nwe character without the additional product needed.
    That said, Vick's chest looks pretty good compared to a lot of other lean masculine bodies we have seen in the store!
  • Vick vs. Victoria: I think you need to render them next to each other, scaled to the same size whatever way, not front/back. I might be too bad at discerning, though.
  • Thanks for the info everyone, and the comparison images. Very informative.
  • davesodaveso Posts: 8,329
    edited January 2024
    So does this new product overcome what a lot of people were complaining about as far as the masculine chest and nipples on G9?  I assume it can be used on any G9 base and overcome the chest making it more masculine looking?
    Post edited by daveso on
  • columbine said:
    OK, so, Vick ...
    What you get in the "Victoria 9 HD Masculine Add-On" kit is two actor load icons, one HD and one not, four surface load icons, and three new shape sliders.
    "Vick," loaded as an actor (HD version), has ALL of Victoria's normal sliders applied full-tilt. V9 Body, V9 Body HD Details, V9, V9 HD Details, V9 Proportions, V9 Head, V9 Head HD Details ... all remain at 100%. To these are added the three new sliders V9 Masculine Body, V9 Masculine, V9 Masculine Head ... all, again, applied at 100%.
    Putting Victoria 9 next to Vick ... Vick has a slightly larger head, especially the forehead, top of cranium; a wider and more pronounced jaw; a slightly more pronounced chin; a male chest that actually does look like a male chest and not "we tried to shrink these breasts down to pectorals and failed"; and his eyebrows are level, not angled up to the outside corners like Victoria's. He is also considerably taller than Victoria, but wait for it ...
    The fun bit (THIS IS WHAT'S SHOWN IN THE RENDER): We take Victoria and put on Base Masculine. No other changes, just apply Base Masculine 100%. We also adjust her Proportion Height to be the same as Vick's. Victoria's default Proportion height is a wee -4.5% (that's a minus sign in front, there); Vick's is 20.5%. NOW WE HAVE two figures who differ only in the angles of the eyebrows, the slight difference in head/jaw size, and the fact that Victoria still has definite breasts even with Base Masculine on. (And in the image, I have figleafed them with Vick's arm so the mods won't get mad, but take my word for it.)
    So, bottom line, if you want a male version of Victoria this kit does provide a few things you can't get with just Base Masculine, notably the chest shape. But it doesn't provide much more than that.
    Pax: Vick's nipples are actually in a different location. They're lower on the pectorals than they are if you try using Victoria's surfaces. You can see the change very clearly if you put Victoria's surface 1 on Vick instead of his own surface 1, then turn on his nipples so they stand up ... you get erect nipples where the areolae are NOT, and it looks very bizarre.
    Thanks for that! It makes me wonder, since you say it loads with all of V9 at 100%, then applies Vick at 100% too... can you use the V9 Masculine Body on other feminine G9 models to effectively zero out their breasts, or does it only work for V9? (Considering what you said about the nipples?)
  • columbinecolumbine Posts: 470
    Brief tests suggest: Not entirely well.
    Vick's sliders on Freja created a definite "we were trying to create a male chest by ironing out the breasts" wrinkle, unless you took the Vick body down to about fifty percent ... at which point the pectorals began to look definitely breasty, so no win there. And you need to apply Vick's surfaces (or some other G9M surfaces) or the nipples look strange.
    Going the other way around, starting with Vick, and using Freja sliders to try to get a somewhat more muscular version of Vick (Freja is WAY more muscular than Vick) worked somewhat well ... to a point. If I gave it more than fifty percent Freja, again, he began to go from "nice pecs" to "we can't really call those pecs anymore, can we now?"
    I may experiment more in the future, though; it seems to me you might be able to arrive at something with a fair bit more tinkering that I don't have time to do right now.
    See my comment just above. I don't have time to play with it a LOT right now, but I don't think you're going to be able to use it to masculinize a G9F chest convincingly. You'd do better mixing and matching other figure shapes to try to get there.
    (Do NOT apply Victoria 9 Masculine onto a generic G9 with Base Masculine on, unless you are fond of body horror. Trust me on this.)
    You're fantastic, thank you for all your testing!
    thanks. I guess I'll save my money
  • TimbalesTimbales Posts: 2,456
    I think Vick still has the defined shape under and between the breasts that's visible. Best to keep a shirt on him.
  • JOdelJOdel Posts: 6,322
    The Vick mrph comes across as a rather decent late-teen male figure. Which is not unwelcome, depending on what you are doing a render of. And probably useful as a starting point without needing to jump through whatever hoops are necessary to get to a masculine base before starting.
    Not convinced that it's worth the price to me, even though I am being offered a discount.
  • barbultbarbult Posts: 27,618
    edited January 2024
    I thought Vick looked very feminine in most of the promos.
    Edit: He looked like V9 with a flat chest. The promo with the muscles is rather misleading. That is not the body you get with the product, as far as I can tell. I didn't buy it, so I can't verify that it is not included, but I sure didn't see anything hinting that it was included.
    Post edited by barbult on
  • felis said:
    The Moonloght Magic outfit https://www.daz3d.com/bw-dforce-moonlit-magic-outfit
    says it includes heels and a book, but there is no promos showing that.
    Can someone post an image how they look?
    Why would you want to know what you're buying? Can't let this novel requirement propagate... wink
    In some ways, given the hat and the reported inclusion of a book, it feels as if it'd be more of a Halloween/Valentines crossover set.
    Regards,
    Richard
    Sorry there were promos showing them but the promos weren't all uploaded for some reason, at first only one promo was there and now it seems bugged and has a bunch of doubles. Sorry about that.
  • DustRiderDustRider Posts: 2,913
    I realize this is a bit late, but this product was new on Monday and is still on sale today, so I hope it's OK.
    I just really wanted to give a shout-out to Roguey and Strangefate for STF Tribal Armor for Genesis 9 and Genesis 8 Female and STF Tribal Body Paints Vol.1 for Genesis 8 and Genesis 9. I've been investigating these for a couple of hours now (finally). All I can say is WOW!! For anyone who does fantasy/jungle/Amazon type renders, these are fantastic. As usual, the attention to detail and the potential options are outstanding. Yes, it is a bit more expensive than the standard DO products, but IMHO the quality and detail is much better than the vast majority of DO's (and many other PA products, but that's just my opinion). As expected, the Tribal Armor outfit lives up to the standards of their earlier clothing products. I was a bit hesitant on the Tribal Body Paints because often they just don't looks as good in general use (without some extra work) as they do in the promos (i.e. lack that little something that makes them look realistic), but for me these definitely didn't disappoint. Tons of options with the ability to use two layers. Note however that they do use geo-shells, but if you are OK with that, then they are really top notch.
    The other plus for me was that they are for Genesis 8/8.1 as well as G9. Since I still don't have a lot of G9 stuff for this genre; it's a huge plus and helped me make the decision to go ahead and use up a huge part of my budget on these. I should also mention the their other recent releases work very well with these, especially STF Tribal Witch Doctor Undies and Body Paint for Genesis 9 and Genesis 8 Female. Probably the biggest drawback to their outfits is that it can take a bit of work to kit bash with their stuff simply because it's hard to match the details/realism with many ot the other products available (but it can be done with the right content).
  • felis said:
    MelanieL said:
    Ah, that's the advantage of me not looking in the shop until afternoon (my time) - most days the glitches have been shaken out by then!
    Yeah - lots of new images added. Although still no of the mysterious book.
    And a bit weird as it was released yesterday - so it have taken 1½ day to add them.
    Sorry we had images of the book but it didn't get uploaded. The promos are glitched for some reason. If it helps the book has open and close morphs. In the original promo it had the mannequin using her hand to allow the book to float opened with pages flying around the room. Well it used to be a fully skinned girl but was too much skin xD
  • SapphireBlueSapphireBlue Posts: 1,418
    edited January 2024
    Like Barbult, I too thought Vick looked very feminine in many of the promos, like Victoria playing dress up. So I felt that if one really needed a family resemblance, it makes sense to just use her morphs to get there.
    As for the chest issue, what's stopping us using a G9 male body and her head morph? I decided to create a quick version of V9's twin brother, after seeing Columbine's test render. This was just very quick: I used Thalius's body morph here with V9's head morph and tweaked the head/neck just a tad for the test, made "Victor" a bit taller, changed the brows and used V9's male mats.
    Victor and Victoria
    Post edited by SapphireBlue on
    After the previous quick try at a V9 twin, I wanted a more natural looking Victor. Someone that looks like her, but not so identical. I just morphed the previous test version a bit here and there.
    Victor and Victoria at home
    Victoria's plotting something. I don't think she's impressed with a new brother taking the spotlight...
  • alienareaalienarea Posts: 547
    I wonder whether we will get a Mikkaela for Michael 9, just to show Genesis 9 works both ways.
  • caravellecaravelle Posts: 2,789
    edited January 2024
    Supra A90: The highly esteemed PAs really don't seem to realise that many of their customers are fed up with these pompous luxury or sports cars and need normal cars for normal street scenes. Electric cars, too, please, and not just big, fat SUVs.
    https://www.daz3d.com/grook-caveman-for-genesis-9 heart
    Post edited by caravelle on
    It, like all the other vehicles by the same guy, are exclusively Editorial License, which means you can't use it for anything beyond your own desktop wallpaper anyhow (Which, if you really wanted a wallpaper of the vehicle that badly, you'd most likely just do a Google image search of the real thing), so it's useless. I imagine if they weren't all Daz+ bargain-bin items, they would go largely unsold.
  • xyer0xyer0 Posts: 6,518
    TruForm at Rendo makes lots of normal cars (as well as sports cars and luxury cars and electric cars), and you can get them cheap on sale.
  • MimicMollyMimicMolly Posts: 2,376
    I actually want this for the skin because Michael 9's skin has a hairy chest and stubble, which is unusable for my female characters and for my child characters. It's a shame because it's an otherwise perfect skin tone.
    I don't believe the V9 Masculine add-on comes with any new skin textures, just presets for the existing textures V9 comes with.
  • ElorElor Posts: 4,193
    I tried one of the de-aging product with Michael 9 and yeah, his skin didn't work at all in that context blush
    They are 6 jpg files in the Runtime folder:
    • /Runtime/Textures/Daz/Characters/Genesis9/Victoria9Masculine/Victoria9Masc_Body_NM_1002.jpg
    • /Runtime/Textures/Daz/Characters/Genesis9/Victoria9Masculine/Victoria9Masc_BodyM1_D_1002.jpg
    • /Runtime/Textures/Daz/Characters/Genesis9/Victoria9Masculine/Victoria9Masc_BodyM1_SSS_1002.jpg
    • /Runtime/Textures/Daz/Characters/Genesis9/Victoria9Masculine/Victoria9Masc_BodyM2_D_1002.jpg
    • /Runtime/Textures/Daz/Characters/Genesis9/Victoria9Masculine/Victoria9Masc_BodyM2_SSS_1002.jpg
    • /Runtime/Textures/Daz/Characters/Genesis9/Victoria9Masculine/Victoria9Masc_BodyM_R_1002.jpg
    http://docs.daz3d.com/doku.php/public/read_me/index/92574/file_list
    edited January 2024
    They have different names, but are they actually different/edited texture compared to the male nipple placement maps that came with V9?
    Post edited by Timbales on
    I don't have Victor, but @Columbine said that about Vick's nipples:
  • lou_harperlou_harper Posts: 1,163
    I admit, I have a soft spot for zombies, and I quite like LA Ghoul for Genesis 9.
    Zombies usually have a lot of soft spots, depending on how long they have been undead.
    Richard, are you still out in that catnip? laugh
    Um, well...
