Dforce weightmapped 100%, but the fabric doesn't want to fall (solved)
James
Dforce weightmapped 100%, but the fabric doesn't want to fall.
could there something else holding the fabric?
Post edited by James on
Are your simulation settings default?
If you add a plane and apply dForce to that, will it then simulate?
simulation settings at defulat.
Add a plane, apply dforce, it falls
https://prnt.sc/BocwcJUR_TsM
Is the weightmap the only way you controle what is simulated, or do you have different surfaces with individual settings?
Well, the cloth is not created by me.
And there seems only one surface.
I added the dforce map, coz it won't fall.
What other settings could there be?
It doesn't look it has any other map, other than the usual weight map for the rigging.
I thought it was you who had created it.
I was thinking that maybe the dynamic strength had been turned down.
OMG your guess is spot on.
Thank you.
I would never guess it, cos I'm not familiar with that stuff.
