Adding to Cart…
So cool!
version 3 will have some visual feedback
so you can see what's going on during the stretching process
lets recap how this will work
- install imagemagick
- install the new mcjSqueeze.exe utility in the same folder as imagemagick's convertexe
- create and select a camera in DS
- launch mcjSphericalCam
- click the auto-focus button
- click the Animate camera button
- exit
- render the 72 or 128 tiles
- click the create Stretcher.bat button
- select one of your 72 rendered images
- click the Run Stretcher.bat button
- watch the 72 tiles being stretched, takes about a minute
- click the create montage.bat button
- click the Run montage.bat button
- watch the 72 stretched tiles being assembled by imagemagick into one big 6000x3000 or 8000x4000 panorama (takes a few seconds)
Could you by chance just package up all the needed modules you mentioned above in one zip?
i prefer not to distribute imagemagick's software
i understand it would be convenient, but this way i don't have to deal
with versions, platforms (32bit 64bit ... someday windows10) and copyrights
which exist in some form even on freeware and open source
btw, i'm in the process of uploading the new version and adjusting the manual page
OH.. I thought it was something you coded. Sorry sir. I'll be quiet then! lol
OK.. Googled, found, downloaded, installed! :-)
it's Ready !! it's Ready !! it's Ready !! it's Ready !! it's Ready !! ( i hope )
https://sites.google.com/site/mcasualsdazscripts5/mcjsphericalcam
( if you downloaded the script on July 2 before 9 am eastern,
you may have the version that will fail the stretcher.bat phase
so get the new one that was posted a few minutes later )
step by step, today's session
- i have convert.exe, montage.exe and mcjSqueeze.exe in c:\imagemagick
- i set up a non-animated scene in DS4.8
- create a camera at 0, 105, 0
- i iselect the camera
- i launch mcjSphericalCam
- i click the "Location of image magick convert.exe" button and select my c:\imagemagick\convert.exe file
- i set the Horizontal Tiles slider to 12
- i set the resolution slider at 256 pixels
- i click the Auto-Focus Button (61mm)
- i click the Animate Camera Button
- i exit mcjSphericalCam
- i render frame 0 to 71 in 3Delight 256x256 in C:\Users\Public\Documents\SkyBalls\ds48v3 the root name is pic.png
- i click the "Create Stretcher.bat" button
- i select C:\Users\Public\Documents\SkyBalls\ds48v3\pic000.png ( one of my renders )
- i specify i want the batch file to be C:\Users\Public\Documents\SkyBalls\ds48v3\stretcher.bat
- i click the "Run Stretcher.bat" button
- i watch the 72 image getting processed, takes a few seconds
- i click the "Create mcjMontage.bat" button
- i select out_pic000.pg, ( one of the 72 images that were stretched a moment ago ! )
- as the mosaic/panorama output image, i chose the name July.png
- the script didnt ask me and chose montage_out_pic.bat as the batch file name, it will be in the same folder as the images
- i click the "Run mcjMontage.bat" button
- and a few seconds later, it's there ! a nice 3072x1536 panorama of the mcjCastle
so it works
( if you downloaded the script on July 2 before 9am eastern, you may have the version that will fail the stretcher.bat phase so get the new one that was posted a few minutes later )
This is awesome. I'll get it and hope that I have some time this weekend to play! THANKS Casual!
welcome,
it has to work it has to work
i hope it works :)
yah it will
i 'm pretty sure
chances are !
in fact i already put the castle skyball to good use for the mcjTeleBlender thread
So i chimed in a few pages ago looking forward to seeing your final results. So I'm about to start trying to figure this out, pretty new to 3D modeling and animating. I'm very interested in this in use for 360 content for AR or VR, I've been doing a lot of stuff in UNITY and UNREAL engine while playing in pre-rendered stuff like this as well.
I'd like to try using this new workflow you guys have come up with for some animation tests, but I've noticed you never render out with your models. Are you using the photosphere that you create stitching multiple images together just for enviroments and backgrounds? I ask because I've yet to see a spherical image rendered with a model in it.
I have found using Cycles Render in BLENDER you can set camera to Equirectangular, but you need a LOT of light...which is tough since you are able to see everywhere in the image. I know DAZ really well, as it is what I learned on, just now figuring out BLENDER and it is great and tough at the same time, so if i could do 360 renders in DAZ that would be great.
With your script can I move the camera and animate?
Here is a still of my first render I did in blender (with cycles and equirectangular camera)
And here is a 60fps animation I did shortly after
http://webmshare.com/play/YLMn0
I can then use the equirectangular or spherical image inside of a VR headset, or on a 360 video/photo player.
the mcjSphericalCam script is indeed intended to create non-moving panoramic images
those images when applied to the surface of giant spheres make good backgrounds
the illusion is maintained as long as the camera doesnt move too far from the center of the giant sphere
rotations ( looking around ) doesnt break the illusion
in the Daz Studio IRay renderer and in Blender Cycles, there is an "environment" image ( called world environment in Blender )
if you use one of the images found on the net or created using mcjSphericalCam
you can get the same 360 degrees background illusion as you get when applying it to a giant sphere object
and the panoramic image serves as lighting in the scene
so if your panoramic image contains the bright-white sun, there will be light coming from that direction illuminating the scene
sometimes the panoramic images are distributed in HDR format
and it may be preferable to use the HDR image for lighting purposes
the equirectangular Camera ( not the same as the world ) lets you render your Blender scene as an equirectangular panorama in one shot - so it does what mcjSphericalCam does, but without the complicated mosaic Building
so, recently, i used an equirectangular panorama as the Blender World Environment
it's an image of a warehouse i got from the sIBL archive
and i rendered a Daz Studio scene of a character walking .... in Blender
( i used my mcjTeleBlender script to do the daz studio to Blender ttransfer )
and i used Blender's Equirectangular camera to render my scene at a 4000x2000 resolution
and posted it at youtube, I had to use the special youtube program to "mark" the video as being a Youtube-360 video
https://www.youtube.com/watch?v=kJaiETGp9b8
on my youtube and on my web site there's a lot more examples of using the equirectangular images as background and lighting
image below : rendered in BlenderCycles, the environment sphere is using an equirectangular/spherical image as the visible backdrop and for lighting - i probably added a sun light also
Hi Casual. This looks very cool but when I get to the step where I run the stretcher.bat I get errors and no images are created. Here are a few lines of the errors popping up., any idea why? I do have the mcjsqueeze in the same directory as convert.exe and I did point the script to that path as first step. Thanks!
warning/module.c/GetMagickModulePath/674.
convert.exe: NoDecodeDelegateForThisImageFormat `TGA' @ error/constitute.c/ReadImage/501.
convert.exe: UnableToOpenBlob `out_Fancy': No such file or directory @ error/blob.c/OpenBlob/2699.
convert.exe: NoDecodeDelegateForThisImageFormat `' @ error/constitute.c/ReadImage/501.
convert.exe: NoImagesDefined `Closet071.jpg' @ error/convert.c/ConvertImageCommand/3230.
it sounds like imagemagick's convert is separated from the other files that come when you install imagemagick
possibly .dll files
or the way you installed it, windows was not told where to look for those
one of the messages seems to indicate something fails when looking for imageMagick's support files
read/writing TGA files is probably no part of the barebones convert.exe
the short version is, you could re-install imagemagick, a recent version
they call them "binaries" when they are packaged for end-users
http://www.imagemagick.org/script/binary-releases.php
then make sure the skyball batch files refer to that fully installed convert.exe
I don't think that's it Casual. I installed ImageMagick from the binary distribution just last week so it's current and complete. I wanted to give this a shot but it's not going well so far. Will keep trying.
wild guess : maybe if the image filename is toto.TGA instead of toto.tga ...
the message about "NoDecodeDelegateForThisImageFormat "
sounds like there's a missing element in your imagemagick
in windows installations, often, programs like imagemagick install environment variables
for example, it sets a variable named IMAGEMAGICK to the complete path to where imagemagick is installed
when my .bat script calls convert.exe, the program convert .exe may ask windows "where is "IMAGEMAGICK" because it needs to use a TGA decoder (delegate) located there
if during the installation the variable setting was blocked by windows security or even virus scanner, window may answer "no idea what you're talkin about"
if you google for imagemagick delegate
or the other error messages you may find the reason
http://www.imagemagick.org/discourse-server/viewtopic.php?t=20599
HOW TO convert your spherical renders into FaceBook 360 VR images
Lets say you succesfully created a spherical image which looks like this and is 6000x3000 pixels
get exiftool.exe http://www.sno.phy.queensu.ca/~phil/exiftool/
and you placed it in the same folder as exiftool.exe
open notepad
type
save this as a textfile named chuuuuuu.bat in the same folder as exiftool.exe and pikachunettes.jpg
Run chuuuuuu.bat by double-left-clicking on it in your windows Explorer
there you have it, your pikachunettes.jpg image will now be accepted by facebook as a 360 degrees panorama !
your friends will be able to look around
360 IMAGE IN FACEBOOK
though 360 images dont seem to work on android with chrome
New Trick !!
If you render as PNGs with no environment/backdrop, you get PNGs with transparencies
if you use my script to "massage" the tiles, and use the png format, your tiles have their transparencies preserved
BUT
for now, the montage batch file does not produce PNGs with a transparency
so !
use my script to generate montage.bat
open montage.bat in notepad
replace
"C:/imagemagick/montage.exe" -geometry +0+0 -tile 12x6 out_texas00.png out_texas01. ... ... ...
with
"C:/imagemagick/montage.exe" -background none -geometry +0+0 -tile 12x6 out_texas00.png out_texas01. ... ... ...
and you'll get your spherical render with an alpha layer
which you can then composite over any spherical environment map
Note
i did a new mosaic render ( no environment-background = important ) Daz Studio Hardware render
and rendered my tiles as 12x6 500x500 pixels tiles PNGs,
which gave me a 6000x3000, PNG Photosphere ... with transparency layer ( using the aforementioned modification to the montage.bat file )
so in Paintshop i was able to composite it on top of an equilateral environment map from sIBL archive
BUT i accidentally ended with a 6000x3012 jpg image, and after tagging it with exiftool Facebook didnt accept it as a 360 degrees VR image
re-BUT i cropped it to 6000x3000, metatagged it and this time FB accepted it
Are you on Facebook? If so I'd like to connect with you there if possible..
You can find me under Rich Wolffie McCormick
to make this post a a legal Freebies post, here's a free script to zero the position and rotations of the currently selected node
if( node = Scene.getPrimarySelection() ) for( i = 0; i < 6; i++ ) node.getProperty( i ).setValue( 0 );
Hi there
my facebook is Jacques Squerre
almost all of my posts are public
i only have 12 facebook friends and i think that's all my sociability can handle
one place where you can follow my 3d/daz activities day by day is here: http://mcasual.deviantart.com/gallery/
and my gallery is so safe-for-the-workplace, i think DA will one day ban me ( kidding )
It's too bad you don't have your page set up to allow "Followers" on Facebook. I rarely go to DA, it's just one more stop to plug into my brain while I'm a Fb nut and am on multiple times a day..... I found you but yea, no "follow" button... :-(
thanks i didnt know about the fact i was unfollowable :)
i opened it !
recently i was showing how to make FaceBook 360 images using tmy mcjSphericalCam script and exifTool
https://www.facebook.com/photo.php?fbid=10155014246764746&set=rpd.595934745&type=3&theater
Awesome. Now following! :-)
