Any way of Carrara working out the surface area of an object?
HeadwaxHeadwax Posts: 10,566
edited December 2023 in Carrara Discussion
Hi Brain Bank :)
 say I have a flat irregular plane (think a surfboard fin plan or a random shape).
Was wondering if there was any way in Carrara to get an automatic area measurement of it - rather then counting sq cm's by eyeball?
thanks in advance ;)
Post edited by Headwax on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,590
    a 3D printer slicer program should do this
    Meshmixer could do it if you still have that
    thanks Wendy, will check in those, was hoping carrara had a hidden talent ;)
  • Bunyip02Bunyip02 Posts: 9,345
    Do you have a CAD program ?
    Did a screenshot of your pic, saved as jpg.
    Opened CAD, went to Insert an image
    Once image was in drew a reference line and obtained the length
    Worked out the scale ratio assumming a 15cm length
    Applied scale to inserted image
    Drew a Polyline around the fin
    Clicked on Polyline to get the Area, which was 74.084 cm2
    EDIT - LibreCAD is free, was able to get a Polyline area out of it but was not as User-friendly as CorelCAD which I obtained through a Humble Bundle package.
    1903 x 924 - 1M
    Post edited by Bunyip02 on
    LibreCad - just tried exporting a cube primitive from Carrara as a dxf file.
    LibreCAD can import a Block which is a dxf file. File - Import - Block
    Then Tools - Info - Polygonal Area - trace around the area you want, and read off the Area value in the Command Line
    If you need more details about this method just yell !!!
    1918 x 1035 - 99K
    Polygon Trial
    Quick Carrara model
    LibreCAD
    NOTE - I have not checked any issues with unit differences in the conversion, will do if you are interested ....
    2263 x 1033 - 474K
    1921 x 1040 - 121K
    Thanks Bunyip 02 :) Very kind of you to go to all that trouble and making such a clear walk through! . Ah the areas just need to be relative rather than absolute. The idea is to compare fin areas, so to take a planshape and tweak it but still keep the same overall area.
    I have a few free cad programs plus amateur autocad, I'll check those out ! Thanks for the idea and I'll keep an eye out for humble bundle corel cad.
    I see they are doing Christmassy things at the moment.
    Bloody hot today!
  • StezzaStezza Posts: 9,249
    ahh... you need to find the area under a curve and above the x-axis modeled by function f(x) in the domain interval x within [a,b]. This method requires knowledge of integral calculus.
    this little duck has NFI cool
    ha ha you sound like the research gate papers I have been reading on aerodynamics for the last two months - people get grants for anything - like some guys figured out if you put more support under the part where you stand on a hollow surfbaord then it flexes less :)
    random pic showing vortex generators (left fin) and passive leading edge slots  (both fins)  - carefully sanded ha ha
    the little holes at the rear of left  fin are supposed to be for inducing a passive venturi to reattache the laminar boundary layer at high angles of attack - well that wa s my idea anyway ;)
    let you know if it works  (probably work better if I sanded themproperly)
    the grooves are supposed to interrupt the spanwise flow and reduce the induced vortex drag coming off the tip where the high and low pressure ares try to mingle - kind of like winglets on air-o-planes
    4128 x 3096 - 3M
  • be careful mate heart
    lots of sharks munching on people lately
    I have the new invisability cloak the Chinese just invented :) Thanks for the warning. Had a surf tother day surrounded by about  thirty dolphins and their babies . That was interesting. The buggers never look where they are going. Too busy showing off
    Hi Wendy did you mean Meshlab? found this How to Measure Surface Area of a Mesh | Foundry Community   - you need to divide by two to get the correct answer in sq cm ?
    Couldn't see in in my Cura slicer though
    Bloody hot today!
    Check that you can import a dxf file in your CAD programs, most will have the Polyline/area hidden away some-where. I used AutoCAD all the time when I was working as a Design Drafter many years ago.
    Meshlab sounds interesting as well.
    Definately hot, been on my laptop as my graphics computer does not like the heat apart from a few hours early in the morning or late at night, and I am not a morning person normally !!!
    possibly both do it
    Meshlab does do a lot of things but it was Meshmixer, I recall it having this function and Google confirms it
    https://meshmixer.com/
    Did a comparision of Meshlab and MeshMixer both of which I have installed on my Graphics Computer
    Meshlab
    Edit - Select Faces in a Rectangular Region
    Filters - Quality Measure and Computations - Compute Area/Perimeter of Selection
    MeshMixer - could not find anything obvious for Surface Area, mind you I am only using the program for the first time
    1923 x 1043 - 130K
    796 x 766 - 121K
  • DiomedeDiomede Posts: 15,459
    Here is a suggestion for volume of oddly shaped objects that has only a small chance of success - but not crazy talk.  Start with a 1unit x1unit x 1unit cube and stack them vertically to build a tall water tank.  Use a shader to demark the vertical side of the cube in 10 steps or 100, or whatever level of accuracy you need.  Fill with a Fluidos amount of water bigger than your object.  Take your object and lower it into the fluidos tank.  Note how high the water level goes on the calibrated tank.  Subtract the initial level.  Calculate volume of odd shaped object from difference.
    - So much can be wrong about this suggestion!  The internal math of Fluidos might not work this way at all.  Or, the way in which Fluidos simulates the flow of water might not take into account volume of water.  Even if the internal math of Fluidos could work this way in an appropriate program, Carrara physics might not.  I haven't tried this, and I have not used Fluidos enough to have a guess if this would work.
    EDIT:  The metric based world should be able to choose a unit that converts easily to a volume.  Meters to liters, or whatever.
    Post edited by Diomede on
  • under Stability
    Thanks Wendy !!! Not an obvious place to hide it !
    798 x 770 - 101K
    Looks like Headwax is spoilt for choices now !!!  - 1 Cubic metre = 1000 Litre
    A typical Australian would use the 'ROE' method. wink
  • cdordonicdordoni Posts: 584
    Deskartes 3D Data expert (free) also has some tools for volume and surface area.
    WendyLuvsCatz said:
    possibly both do it
    thank you Wendy
    ha ha I had to google it. I hated maths at uni. The last purely maths thing I did I got 49 out of 50 first semester and 1.5 out of 50 the second semester. So I luckily passed...
    thanks that looks very interesting will check it out ! Deskartes 3D Data expert
    Bloody hot today!
    thanks will check that DXF , yes I like to sleep in till 7.00 am but that sun blasts in at 5.30 :( :)
    thanks for those walkthrough and yes, spoilt for choice! Better than the opposite :)
    wow, that's a bit of lateral thinking! When i get my head around Fluiodos again I will try it :)
    just ran an obj through meshlab and meshmixer and got the same area - so that's a relief :)
    laugh
    = Rack Of Eye
    Stezza said:
    laugh
    Heh, sorry just saw this Stezza
    = Rack Of Eye
