I'd like Navels for G8F
There are not quite a lot of belly buttons in the store.
I am still searching for a detailed bellybutton geo grafts with extra HD options, that don't require geo shells.
  • felisfelis Posts: 6,479
    So essentially the same navel as G8F base, but with more geometry?
    Do you intend to create morphs yourself?
    Oh, with more geometry, please.
    i'm not a vendor, but I could try to make some morphs as freebies.
    edited December 2023
    If I made this into a geograft, would that be what you are after?
    1021 x 684 - 134K
    Post edited by felis on
  • LauritaLaurita Posts: 288
    I think these look great especially as you can dial them in and combine them in any way you'd like to:
    https://www.daz3d.com/ng-hd-navel-morphs-for-genesis-8-and-81-female
    this looks excellent :-)
    It is actually my first time for making a geograft. I have known the concept but never done it, and there was some trial and error.
    But I think it works now.
    Attached is the G8F_HiRes_Navel.
    To use:
    1) Load the Navel
    2) Fit it to G8F (I must have done something wrong when saving it, as it doesn't fit automatically)
    3) Copy the Torso surface material to the Navel
    Some navel morphs will work on the geograft as projected morph - some gets a little wonky.
    The attached image is a random G8F character with the geograft and an existing morph.
    zip
    zip
    G8F_HiRes_navel.zip
    120K
    1200 x 1200 - 2M
    798 x 502 - 541K
  • thank you, well done.
    I get this missing file message:
    "[...]/Blender/Daz_export/g8f_base2/g8fbasetorsomapd_1002.jpg"
    And true, it doesn't attach, but I will try to figure that out.
    so thank you :-)
    The missing textures is my mistake. I forgot to remove it before saving. I can clear it in the duf.
    But why it doesn't attach I don't know. Can you post an image of what you are seeing.
    I don't know, what happened. I just tried it again and this time it worked. So solved.
