READY - Rendering daz studio scenes as skyballs ( equirectangular / spherical images )
13
  • mCasualmCasual Posts: 4,607
    RAMWolff said:
    I have an off topic question... I have a seamless tile running around a "horizon" globe I created using a sphere... it's showing a seam though when rendering. I used spherical UV mapping so that shouldn't be happening! Any suggestions?
    if it's a hardware rendering, and the sphere is low-poly, there's sometimes errors in texture placement
    software renders usually render ok
    the daz studio primitives usually behaves well ( see image below )
    there too it's better to have high poly spheres, like 32x16 sides/segments
    make sure that in the surfaces tab, the "Tiles" settings specify exact numbers of tiles ex: 4 Horizontal Tiles, not 4.28
    you could try a different sphere like the free ones i published here
    https://sites.google.com/site/mcasualsdazscripts5/mcjsphericalcam
    512 x 512 - 199K
  • RAMWolffRAMWolff Posts: 10,373
    Thank you. I saw those but wasn't sure which one to download! lol I need one big enough to create an environment with, not planet sized but sort of Moon sized. I have got the land and water disks with morphs created.
    Thanks for your help, as always! :-)
    Free PoserFirefly Office Environment map 4096x2048 pixels
    https://sites.google.com/site/mcasualsdazscripts5/mcjsphericalcam/montage_out_boca_.png?attredirects=0&d=1
    it's also accessible in the attachments section (click on the down-arrow) of the mcjSphericalCam page
    and there's the 2K version 2 posts before this one
    1000 x 500 - 468K
    I need to pay more attention.. you clearly stated 32 X 16. My bad. SPANK ME! lol Thanks again for all your fabulous freebies and advice.
    using the free 4K panorama in Blender/cycles
    1920 x 1080 - 176K
    edited June 2015
    using the free 4K panorama in Daz Studio 4 - Uber Environment 2 - and a shadow-catcher plane
    (youtube-search for carnite, shadow catcher for a tut. about shadow catchers )
    1920 x 1080 - 145K
    1920 x 1080 - 749K
    Post edited by mCasual on
    I haven't had any time to actually set up a scene. I have to do that right?? LOL
    Note - for lighting purposes the UberEnvironment sphere is good
    but for background images it severely distorts the spherical images
    most of all at the sky zenith
    i found that my free 128x128 spheres work better
    note that sometimes i send Daz Studio scenes over to Blender cycles, using mcjTeleBlender
    and i include a sphere object like that with a spherical map applied to it
    and the ambient color/strength at 100% white.
    Fig 1 - a DS3 render, contrary to previous renders, it's my free 128x128 sphere instead of the Uber Environment sphere
    and there's less distorsion, maybe my UV layeout is better i dont know, i think it's mostly because it's more finely faceted
    I'm feverishly working to release the script and special utility mcjSqueeze !
    1920 x 1080 - 805K
    Which one is the 128 X 128 sphere? You have the four labeled differently on the download page...
    mcjSphere12x6.obj (5k)
    mcjSphere16x8.obj (10k)
    mcjSphere24x12.obj (24k)
    mcjSphere32x16.obj (43k)
    I have the bottom most. It was actually way to big as I like the Environ be just slightly larger than the default ground plane in DS (or what ever that's called) lol
    edited June 2015
    oops i had forgotten ( is that English?) to upload it !
    but it's ain the attachments now
    or directly here
    https://sites.google.com/site/mcasualsdazscripts5/mcjsphericalcam/mcjSphere128x128.obj?attredirects=0&d=1
    using mcjElevate one could change that sphere into a small asteroid
    1920 x 1080 - 860K
    Thank you. Ooops, is English... hell it's universal! lol Ooops! ;-)~ Not sure if I have Elevate. No, I don't, just looked. Wasn't sure what that was for. So it can resize something big and have the Y Axis kept to the center? Whenever I resize anything it moves down or up and I have to try to equalize it's center again. Kind of annoying!
    edited June 2015
    dont know if it's what you mean but the spheres on my site are centered at 0,0,0 whereas the usual primitive spheres are centered at the bottom of the page
    a rather important tool i often use to change the center of objects ( essential to install door hinges ! .... well you could also use parenting and null nodes ) is ..... DeltaX15's MoveOrigin script
    but i think DS4 also has in its menus something to do it
    Fig1 an IRay render using the free (jpg) 4Kpixels Poser office panorama
    i think i plucked Amy from a demonstration scene for the midi/keyboard project ... that would explain the pose
    1920 x 1080 - 502K
    edited June 2015
    Just imported it into DS and it's doing the same thing Casual. When I scale it smaller it moves downwards on the Y axis. ;-/
    1348 x 793 - 458K
    Post edited by RAMWolff on
    edited June 2015
    there may be other menus for this
    but if you go in the sphere's parameters tab
    and go into edit mode ( right click on the parameters tab to get the pop-up menu )
    then you see a "Rigging" section
    and using the Y Origin slider, you can change the sphere center to 0,0,0
    1184 x 416 - 69K
    1058 x 630 - 69K
    edited June 2015
    fig 1
    the 128x128 sphere, transformed into an asteroid, using a simple "Perlin noise" image
    in just a few seconds using mcjElevate for DS4.5+
    also ideal to add wrinkles to moderately high poly clothes
    mcjElevate the movie https://www.youtube.com/watch?v=6dP8faP3KMo
    1920 x 1080 - 961K
    Awesome. Thanks so much. Need to leave for work but I'll check that out when I get home tonight. :-)
    Nice asteroid! :-)
    Just home from work. IT WORKS. Great little tip there Casual. Thanks so much! {^-^}
    edited June 2015
    one just has to remember to turn the edit mode off after modifying the Origin-Y
    but if you search in the forum for "origin" i think there's a more direct way to do it
    ...then again maybe not for objects, just for figures
    One thing, once I saved it out as it's new size and then back in again I noticed that once back in Edit mode and the Rigging area the dials shows two Y dials at -3000.00 so I guess that's how it reasserts the need to have the center at the bottom of the sphere.
    edited June 2015
    Daz Studio 4.8 IRay photorealist mode - the free poser office skyball but converted to HDR blurred , plus a 1 meter diameter high intensity point light
    Fig 2 Amy and Julia (the keyblade) at the beach, but Julia's blades don't look sharp enough and she's usually cuter than that
    that's an sIBL-archive 3K HDR environment
    1920 x 1080 - 885K
    1920 x 1080 - 558K
  • DigiDotzDigiDotz Posts: 515
    Looks like another great script -I really need to have any chance of rendering full(looking scenes)
    I get an error In daz
    WARNING: Script Error: Line 1021
    WARNING: SyntaxError: Parse error
    WARNING: Stack Trace:
    ()@G:/Studio/My Library/Scripts/mcasual/mcjSphericalCam.dsa:1021
    Error in script execution: G:/Studio/My Library/Scripts/mcasual/mcjSphericalCam.dsa
    Loading script: G:/Studio/My Library/Scripts/mcasual/mcjSphericalCam.dsa
    looks like its the quote at the end - picout = "out_" + picin"
    Deleted that and the script runs
    edited June 2015
    Thanks i'll make sure that problem isnt in the next release
    which by the way will be majorly different because it will include mcjSqueeze.exe
    if all goes well i'm posting it in the next hour or two !
    turns out that in Daz Studio 3, that script with the error doesnt cause a "crash"
    guess i must leave the comfort of DS3 to complete the script *sigh*
    argh DS4.8 uses 36mm camera backplates instead of the age-old 35mm!
    well unfortunately the release of version 2
    ( which produced such wonderful results with poser and ds3 )
    will have to wait another day
    but but, i'll fix the little bug in the current version
    which did work but .... who knows maybe with DS4.8 maybe it doesnt !
    but at least it wont crash on you
    ( by crash i mean just the script not daz studio )
    Fig 1 - the issue at hand - a broken panorama in DS4.8
    2000 x 1000 - 683K
    daz must have thought 36 was better cause its like ..1 more -chuckle-
    on the plus side, (oh my blob) .. i got imagemagick working, the problem i had was that it wouldnt work with png files. rendering to jpeg in daz solves that.
    edited June 2015
    UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE
    i posted a corrected version of mcjSphericalCam pre-release
    thanks to Digi-Dotz for spotting the error
    direct link to the zip file
    https://sites.google.com/site/mcasualsdazscripts5/mcjsphericalcam/mcjSphericalCam.zip?attredirects=0&d=1
    if i can get it to work in DS4.8 as it works in DS3, the ~~~final ~~~ non-distorting version will be ready soon
    soon being a relative term as Einstein or his dog would say
    and in the case of the release of my scripts you could say it's meta-relative
    ( the sort'of good news is, i get the same problem in DS3 )
    Fig 1 - good news, except for the failed tiles at the top, the system works, in DS3 when using 16x8 tiles instead of 12x6 -
    good news good news - i'll give it another go tonight !
    note : this is not a real room !
    it's a sphere with an environment map
    the environment map i use for this test is by zbyg
    http://zbyg.deviantart.com/art/HDRi-Pack-1-97402522
    Fig 2 TaDa!!! when imagemagick was seeing a black and white image, and i asked for a bmp version of that image,
    imagemagick made a grayscale bmp, because it's a smaller file ... but my mcjSqueeze.exe utility is a bit stupid
    and can only process 24 bit BMPs - so i used a special code to tell imagemagick to make em all 24 bit
    so this increases chances of a release tonight !
    Fig3 ( now we're talkin ) mosaic from 12x6 render tiles , Daz Studio 3 renders
    FIg 4 ( really talkin ) mosaic from 12x6 render tiles , Daz Studio 4.8 renders
    2000 x 1000 - 652K
    2000 x 1000 - 140K
    2000 x 1000 - 140K
    2000 x 1000 - 152K
    OK, I'll hold off. I use DS 4.8. Thanks Casual! :-)
    edited June 2015
    still got to fix 1 spurious problem with mcjSqueezer and it will be ready
    sky by Arqam http://www.sharecg.com/v/3852/view/6/Texture/spherical-sky-map!
    2000 x 1000 - 240K
  • Angela3DAngela3D Posts: 80
    Amazing work on this, Casual. Can't wait to see when it's finished!
