Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
That's really nice! The face reminds me a bit of Alyson Hannigan, when she was a bit younger.
Nice, you've got the beginnings of Natalie Dormer there.
CHEERS!
Very nice, her eyes are looking a bit more 3 dimensional now. The corneal bulge and iris correction work much better now too, as you can see below. Corneal bulge is at 0.40 and the iris correction is at 100%.
CHEERS!
Lovely, if you took the banner off that nobody would guess it was Daz.
CHEERS!
Looking great!
CHEERS!
Very nice. I'm sure as the weeks go by we'll see that she's more than just a pretty face.
CHEERS!
Remade an older v6 scene
Looking good, if you adjusted the eye morphs that I did then that render would pop even more.
CHEERS!
here a quick render with V7.
I think the skin is a little to red but iray has a lot of settings to play with ;)
Gorgeous renders and I love those eye settings.
The incompatibility with older generation skins is a big downer for me, but there may be work-arounds, until the variety of skins improves. For example, here's V7 rendered with dark skin. I changed her base color to dark green and this is the result. I'm sure it could use more tweaking, but there's lots of potential playing with the base color and translucency of the skin.
gratz on that outcome.
Redz, you are killing it, that looks great!
Lovely and this only with a change of the base color ?
I did only get a female hulk so far ;)
Looks stunning to me! V7 is definitely more a poster girl for Iray than V6 was.
CHEERS!
That is amazing. It'd be nice if G3F characters that follow could just be morphs and textures and not new UV's. This render would definitely be a taster for what a Monique 7 could look like if they're going to do one.
CHEERS!
Just playing around with morphs! Really happy with how it's turning out so far! :D Loving the lip shapes that V7 has too!
Hi Jennyver. It will only work with in iray with the iray skin mat, but yes, I just changed the skin and lips base color to Red 0; Green 64; Blue 0
(see in picture) The veins look a little too green to me, which is why I think it needs more tweaking, plus the fingernails will need a different base color. Hope this helps your hulk problem ;P
Just a quick test using a slightly modified character (using the morphs), rendered using Iray, Summer skin.
Ciao
TD
In case it helps anyone, here are some settings I used on the skin and lips of V7's iray mat to get some darker skin shades :) Iray only.
Thx for the Settings :)
My Green was to bright and this gives a little green looking skin.
Will try this after my DAZ new Install on my Notebook (At work... ;) )
Very nice ! And thanks for sharing the settings :)
No morphing. Expression and Pose with hair and outfit only. No makeup even (just a tinge of pink on the lips). I mean, after the Apocalypse who wears makeup anyway? There's no place to buy it and nobody has gotten around to reinventing the old ways.....
BTW, looks like she has a double chin. Some kind of light leakage. I just used UE2 and fiddled with shadow bias a bit--not enough obviously. May or may not redo it or just start a new image.
3 minute (and 1 second) render in 3delight on my 3 1/2 year old i5 quad. Not bad. Not bad at all.
Oh, you can't really see them here but I used smay's Stalker boots (genesis). When autofit came up I told it none and let her rip.
Here some of mine first renders with Victoria 7 /G3F
Lady of the Manor
The stunning and beautiful G3F Victoria 7 with 'Summer' skin texture http://www.daz3d.com/summer-for-victoria-7 and rendered in Iray.
Cheers.
Playing with the sliders to get a male morph. Victor really really needs a bulge morph:)
I thought I saw a V7 render thread, but I couldn't find it last night :-/ Must have been way too tired.
Anyway, here is a really quick test render of V7 and Aeon Soul’s AlphaKini (for G2F) in Iray.
Full image is 1600 x 2000
Adaline in 80's Gym Wear
Adaline http://www.daz3d.com/fwsa-adaline-hd-for-victoria-7 wearing one, of the many textured options, of MEC4D's Birthday celebration freebie 'Back to the 80's' Gym outfit. http://www.daz3d.com/forums/discussion/58276/
Rendered in Iray.
Cheers.
Looks good.
This is G3F with FWSA's Adeline texture, AprilYSH's Leyton hair with Slosh's hair shader, Mada's Fantasy Wrap with textures by Sarsa, Dramatic Lights by OOT using Dumor3D's hdr environ map from his Apocalyptic Plant Outdoors Set 1, a pose from Khory and my original background. G3F has one of my face and body morphs from an upcoming set of mix and match heads'n'bodies.
Looks good.
Thank you mjc1016, much appreciated.
