Texture mismatch for G3F Summer
SimonJMSimonJM Posts: 6,082
Before I raise a report, is it just me or ... are the textures for the G3F genital geo-morph and the base figure a blatant mismatch for the Summer product?
  • LindseyLindsey Posts: 2,011
    Her Actor preset loads with Iray materials. Be sure you're applying her Iray genital map.
  • SimonJMSimonJM Posts: 6,082
    Not on the computer with DS on but that could be it, though I am nigh-on totally certain I checked and double-checked that and all surfaces were AoA-based.
    Now tested again and ... yup, there's a mismatch!
    Load G3F
    Load genitalia
    Apply Summer materials to G3F (AoA shader-based textured applied)
    Apply Summer genital material to genitals (AoA shade-based textures applied)
    You (or at least I!) now have an obvious mismatch in material colours
    The Iray materials (when applied) do not look to show the issue. I will see if a deinstall/reinstall does anything
    edited June 2015
    Hum.. I tried your steps loading g3f, girl parts and AoA materials to both and also loading the Summer character, girl parts and applying the Summer's AoA materials to both. To my old eyes they match in the viewport. Rendering didn't show any color differences either.
    If you do have a color mismatch, definitely file a problem report.
    edit: Do you have the same issue with the Iray materials too?
    Post edited by Lindsey on
  • Zev0Zev0 Posts: 7,123
    edited June 2015
    There is indeed a mismatch with the Iray Materials. 3DLight looks ok.
    Post edited by Zev0 on
    Bizarre, fort me it is the other way round!
    Sounds very odd...
  • jtbetheljtbethel Posts: 46
    edited June 2015
    Looks ok to me both ways, tried loading G3F first then body parts then textured both with 3delight, then iray. Looked ok in both preview and renders
    also tried by loading Summer direct, that was ok too.
    Perhaps he should have gone to Specsavers :)
    I did notice a slight difference when I left the morphing to Summer as the last step, but I removed the offending part, replaced it and re-textured and it was ok again.
    Post edited by jtbethel on
    And it gets worse ... on a different computer, using the same install files, it does not happen!
