Texture mismatch for G3F Summer
SimonJM
Before I raise a report, is it just me or ... are the textures for the G3F genital geo-morph and the base figure a blatant mismatch for the Summer product?
Her Actor preset loads with Iray materials. Be sure you're applying her Iray genital map.
Not on the computer with DS on but that could be it, though I am nigh-on totally certain I checked and double-checked that and all surfaces were AoA-based.
Now tested again and ... yup, there's a mismatch!
Load G3F
Load genitalia
Apply Summer materials to G3F (AoA shader-based textured applied)
Apply Summer genital material to genitals (AoA shade-based textures applied)
You (or at least I!) now have an obvious mismatch in material colours
The Iray materials (when applied) do not look to show the issue. I will see if a deinstall/reinstall does anything
Hum.. I tried your steps loading g3f, girl parts and AoA materials to both and also loading the Summer character, girl parts and applying the Summer's AoA materials to both. To my old eyes they match in the viewport. Rendering didn't show any color differences either.
If you do have a color mismatch, definitely file a problem report.
edit: Do you have the same issue with the Iray materials too?
There is indeed a mismatch with the Iray Materials. 3DLight looks ok.
Bizarre, fort me it is the other way round!
Sounds very odd...
Looks ok to me both ways, tried loading G3F first then body parts then textured both with 3delight, then iray. Looked ok in both preview and renders
also tried by loading Summer direct, that was ok too.
Perhaps he should have gone to Specsavers :)
I did notice a slight difference when I left the morphing to Summer as the last step, but I removed the offending part, replaced it and re-textured and it was ok again.
And it gets worse ... on a different computer, using the same install files, it does not happen!
