Nothing Installs with "Install Mananger"
dramenondramenon Posts: 52
Nothing Installs with "Install Manager" DAZ3DIM_1.4.1.69_Win64
1. Install it
2. Launch it
3. Try to download Daz Studio...
fail, no idea why this would happen. no clues.
  • SofaCitizenSofaCitizen Posts: 2,119
    Under the cog icon menu (top right) there will be two log items - check those for some info. There was an issue a while back regarding a certificate issue or something - that should be fixed now I think but worth checking.
    Also, I am sure this is not the case but just to be sure - check that you have not run out of hard drive space in the location you have specified for downloads.
  • Ah, thank you Logs are awesome...
    2023-11-24 11:47:36.956 [WARNING] :: Network Error: 0 -  : SSL handshake failed
    Now i can start debugging > looks like maybe Windows is stirring stuff up.
  • frank0314frank0314 Posts: 14,763
    The most common cause of this kind of stuff is anti-virus. I seem to recall some others having this kind of issue but I can't remember off-hand what the fix was.I'll ask the other mods to see if they can remember.
  • Search previous threads ~ April 30 Certificate issue...
    Boom Thank you > GoDaddy gdig2.crt fixed it.
  • Moved to Technical Help as it is not a Daz Studio topic.
    Here is the possible fix that has been working for everyone https://www.daz3d.com/forums/discussion/comment/8194876/#Comment_8194876
