Edge Fall off ERROR!
garbanzolasvegasgarbanzolasvegas Posts: 53
edited June 2015 in Carrara Discussion
I am trying apply an edge fall off to an object in the shader and get those errors
A little help~
Post edited by garbanzolasvegas on
    Are you using a plugin for the edge falloff effect?
  • garbanzolasvegasgarbanzolasvegas Posts: 53
    I think so
    I think so... IS there an on board edge fall off in carrara? If i dump the plugins can I then do an edge fall off with Carrara own shaders?
    I don't think there is one. The Fresnel effect in the transparency and reflection channels will produce that effect, but only with refraction and only in those channels.
    My thought would be to check with the plugin developer to make sure that you have the latest version. If you bought it from DAZ, they are notoriously slow about updating the plugins. You'll get better support directly from the dev. from everything I have read.
