[Commercial] MI Modern Military Combat Uniform for Genesis 8, 8.1 Male and Genesis 9 [Live]
13»
  • Lev_cLev_c Posts: 116
    Hey @mal3Imagery  I'm wondering if it were possible for you to release some kind of template for adding our own camo patterns to this product?
    I'm really eager to add the very commonly used Multicam and A-Tacs camo patterns, but without some kind of template, it's a bit beyond me.
  • lilweeplilweep Posts: 2,879
    presumably you can create a "template" from the UV map.
    Substance Painter is fairly accessible/easy-to-learn software for texture painting, although expensive if you keep the subscription active for a while.
    Hi there, I'll attach some templates here later this week.  Thanks
    Awesome! Thank you!
    Do you have any plans for any addons or expansions for this set? Camo's? Accessories?
    Behold.
    Multicam.
    A-TACS FG and EMR Digital Flora next.
  • mal3Imagerymal3Imagery Posts: 722
    edited November 2023
    Awesome! Thank you!
    At the moment no.  I am busy with other projects, but can be something I can do in the future.
    Attached are the UV Maps
    4096 x 4096 - 8M
    4096 x 4096 - 4M
    4096 x 4096 - 6M
    4096 x 4096 - 2M
    4096 x 4096 - 4M
    4096 x 4096 - 5M
    Post edited by mal3Imagery on
    mal3Imagery said:
    Awesome! Thank you!
    Awesome! Thank you!
    Here's some custom camo - a mix of Multicam gear and Russian EMR Digital Flora.
    Also used an cutout opacity mask to remove the AR15 magazines and made a wearable preset that places some AK74 mags in their place.
    Will be able to share all this stuff (except for the AK mags) at some point, alongside an A-Tacs FG camo set.
  • peterppeterp Posts: 4
    Hi @mal3Imagery
    I haven't ever been able to export the MI Modern Military in an FBX without this (see pic) weighting problem. It does not appear to be a problem within daz (I think). I just use this in other apps.
    Great uniform! It'd be great to get it to work out of the box. (I've tried this on both the G8 and G9 versions - and they both have the problem).
    The image is the source FBX. Also, for example, on the right sleeve there seems to be weighting from the chin attached. I've tried this in Maya and Houdini and I get the same results.
    1909 x 1385 - 238K
    peterp said:
    Hi @mal3Imagery
    Hey there.  Thanks for the support.  Unfornately, I do not own Maya and Houndini to test it out and I usually never export daz stuff as FBX since it usually doesn't always work.  If you're seeing weight-mapping issue could be with how DAZ handles the FBX export.  Only way to resolve the issue is to fix the weight map within the 3D app that you are exporting to.
    With the mags they are attached via rigid nodes in DAZ app so those will not have weightmaps at all.  You'll have to parent those to the vest in your 3D app.
    Some extra real-world camo patterns made my Zetasaint as a fun expansion for this great product.
    From left to right: EMR Digital Flora, Multicam, A-TACS FG.
    An image I made using elements of this outfit kitbashed with other assets.
    I've got heaps of ideas for cool add-ons if you're ever entertaining the idea of an expansion to this.
    edited April 2024
    mal3Imagery said:
    peterp said:
    Hi @mal3Imagery
    Hi @mal3Imagery
    Thanks for the speedy response.
    I had contacted DAZ before I contacted you. They said to contact the developer, that's why I reached out to you.
    Here is an image of the character imported to Blender. It also exhibits the problem. Blender is readily available if you have a chance to see for yourself.
    Also, the mags are not my concern. I'm pointing out the skinning problem of the deforming clothing/accessories.
    I have fixed this by painting the weights for this export so I can procede with my project. I was hoping to get it working 'out of the box' for future exports to save time.
    I've fbx exported hundreds of characters and this is first time I've gotten this skin weight issue.
    While I can't rule out that there is something wrong with the fbx export - thought I have exported hundreds of characters without this problem - it currently indicates there is something different about the Modern Military asset.
    2499 x 1789 - 325K
    Post edited by peterp on
    edited April 2024
    peterp said:
    mal3Imagery said:
    peterp said:
    Hi @mal3Imagery
    Hi @mal3Imagery
    Hi @peterp sorry for the late response.
    I am getting what you are seeing when exporting fbx to Blender.
    I tried to see if there were any weight issue in DAZ and I'm not seeing any weight issues.  They're all weighted and I'm not sure how DAZ is exporting the FBX to cause this issue to third party apps.  You'll need to contact DAZ and see if their developers are able to see what is causing this.
    Thanks
    @Lev_c those are fantastic renders.  You're more than welcome to drop your ideas here on this thread.
    Cool!
    - A bit more functionality with the helmet, with the ability to undo the chin strap and have it hanging to the side.
    - A bit more thickness to the plate carrier, to mimic it having the ceramic plates in it
    - A larger molle battlebelt with stuff like mag pouches, an IFAK, dump pouch, and a rigid pistol holster attached. (I've posted a picture below with a kitbashed battlebelt mixed with your stuff)
    - A few more bits and bobs on the plate carrier, tourniquet, caribiners, radio, etc.
    - A seperate radio headset that can be used without the helmet with morphs to adjust it to work with different hairs. Something like a Peltor Comtac or MSA Sordins
    - attachements for the plate carrier, like a groin protector, shoulder pads, neck guards (have a look at Crye's AVS system)
  • TimbalesTimbales Posts: 2,457
    Any chance of you releasing another texture set for a clean version of the construction outfit?
    Hey there.  I might update the outfit to contain a clean version free of charge.  I seen people complaning about there not being a clean version.  Not sure when I will get to that though.
    I have other projects going on that you guys will like for your men.
    Thanks
  • xyer0xyer0 Posts: 6,522
    I hope you will (be able to update construction worker). I'm so glad you bit the bullet and decided to learn Daz rigging (and rigamarole) to bring your creations to us! Thank you!!!
  • I'm very curious to know what has happened to this potential product? Our selection of officer uniforms is...not great, and I would LOVE to be able to purchase this item!
    mal3Imagery said:
    ***UPDATE***
    I am picking up an old project that I have done in the past and re-working it.
    It was a military dress uniform.  It will go nicely along with combat uniform.
    Here's an old render of that military dress uniform with a MD view.
  • ARealitiARealiti Posts: 158
    edited January 2025
    Hi I too would like the officer Uniform, ps I noticed there is no Interactive License for MI Modern Military Combat Uniform Bundle, I have the Interactive License for a lot of your products and would like to purchase for this product as well, they all look great and work will in Interactive rendering engines no problems. Thanks
    Post edited by ARealiti on
  • @mal3Imagery Fantastic designs on contemporary equipment. Having done that professionally in a past life, your attention to detail is solid. I look forward to creating images with your work, yet I would also like to use the characters featured in your promotional images
    As the saying goes "I'm assembling a team . . ."
    They look good in the kit, after all
    Can other unit patches something that can be substituted with Photoshop? Would you have any suggestions?
    Thank you for your time
  • Charlie JudgeCharlie Judge Posts: 13,662
    edited January 13
    mal3Imagery said:
    ***UPDATE***
    I saw the new dress uniforms released today. They are great and I will be picking them up; but what I would like most is a army ceremonial full dress blue uniform. Is there any chance of you releasing one ?
    1007 x 660 - 86K
    Post edited by Charlie Judge on
  • nonesuch00nonesuch00 Posts: 18,882
    edited January 15
    Very cool, changable patches, so much work MI did on this set.
    Post edited by nonesuch00 on
