Daz Studio 4.21 Pro [Diktator Texture with hair GeoShell]
santo.stumposanto.stumpo Posts: 0
Hello everyone, whenever I try to insert a GeoShell of any type (body hair or hair) the texture set on the genitals via Diktator disappears.
How can I do to avoid this?
Even if I reload the Diktator textures it still remains offset, and even undoing the last actions doesn't fix it.
  • Moved to Technical Help as it is not a Daz Studio application question.
    That probably means it has its own groups/materials and the preset doesn't know to turn them off - if yo select the new shell and in the parameetrs pane scroll down through the Shell group you will see a bunch of On/Off buttons for each group and material on the shelled figuers - try turning those for the add-on off, though you may then get a bald spot on the groin - it may be worth trying to copy the surface settings from the torso of the shell to that area in the Surfaces pane).
  • crosswindcrosswind Posts: 10,213
    edited November 2023
    I probably know the shell hair product you're using... if it's from Jepe (Jepe's Bodyhair Project xx), it does not support DK since DK use different UVs on its Torso surfaces... even if you may turn off Visibility or zero Opacity to remove "white" color...
    Post edited by crosswind on
