• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Unity Discussion
Daz export, Unity import, cloth collision and peek through?
plj1225plj1225 Posts: 35
October 2023 in Unity Discussion
Two parts to this...
I've managed to figure out just about every hurdle I've come across with getting Daz chars working with Unity. The only thing still vexxing me - like 'very close to rage quitting gamedev' vexxing me.. it's now 10pm, been working on this nearly 15 hours and no closer to figuring anything out - is skin peeking through clothing during Unity animation.
I've tried Magica Cloth 1 and 2 to try to brute force cloth simulation / collisions. I've tried Unity's built in cloth simulation.. worked even less.
What is the right way to do this? Any and all suggestions are appreciated!
Part 2..
The only thing that seems to / should work is scaling my clothing a few percent larger than the character body. If there's an attribute slider? (not sure the correct term.. being able to adjust a specific property of a item) it works fine. But only if there's a coded attribute. When I go to export, any manual scaling via the scaling sliders doesn't happen. For example: I'll 150% scale something - obviously way too big, but I should see SOMETHING from this - but during the export process everything gets scaled right back down to 100%, then blown back up to 150% at the end. I've noticed it happens for a lot of things.. T / A poses getting reset especially. Why does Daz do this? In the past I've had to Bake Joint Rotations for exports to work properly, but then I'm screwed if I want to go back and work on the character in Daz.
Help?
  • plj1225plj1225 Posts: 35
    October 2023 edited October 2023
    Figured out part 2.. lock it! DUH! Always wondered what the locks were used for, I figured it was just so that you wouldn't inadvertantly change something down the road.
    EDIT
    Still doesn't solve my clothes issues. Argh.
    Post edited by plj1225 on October 2023
  • ARealitiARealiti Posts: 158
    November 2023 edited November 2023
    Hide parts of the figure in Daz Studio before sending to Unity of the genesis character is the easiest way to remove body polygons under clothing. For more refined removal can use the Geometry Editing in Daz Studio to remove polygons of the genesis character before export. I.e. change the mesh to only have one layer of polygons before sending to Unity using the hide/delete geometry in Daz Studio. This way there are no polygons under the clothing to poke through.
    Post edited by ARealiti on November 2023
  • aweswanaweswan Posts: 84
    November 2023
    Have you tried zeroing it out before export ? Not sure if will help. Right click preferences - zer - zero figure.
    November 2023
    Got the clothing figured out! It required the use of an asset on the Unity Asset Store called Clothing Culler, but after a bit of finesse and learning how CC works it worked absolutely beautifully. No more peek through.
    Geometry editor - I'll check this out as well - while I've solved my initial issues now I can see where mesh editing would come in very handy for optimization.  TY!!
    (image shows the problem.. now fixed)
    285 x 551 - 163K
    November 2023
    That clothing culler does look good
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
